FAQ: Official wheel "SPACER" thread!
Old Sep 23, 2009 | 11:14 AM
  #161
JasonZ-YA's Avatar
JasonZ-YA
Default 370Z wheels on 350Z - add pics please
Ok,
I have been getting a lot of pm's asking me about recommended spacers to use when installing 370Z wheels on a 350Z. FRONTS.
350Z owners with 370Z wheels please post up MULTIPLE PICS and your front wheel spacer selection to add to this thread.
OEM 370Z sport wheels:
FRONT 19x9 +47
REAR 19x9 +30
i plan on digging through the threads and adding picks from them and linking those threads to this thread, but not today...
Thanks guys.
-J
Old Sep 23, 2009 | 09:06 PM
  #162
sdZ33's Avatar
sdZ33
Hey Jason I just wanted to say thanks for this thread, it helped me out a lot!!! I just installed my 15mm PK Spacers in the rear today and it makes a hell of a big difference in the looks dept... I was kinda worried about trimming the studs but I got over it and it came out well... I will post pics of it tommorrow...
This my friend is for you... ...
Old Sep 24, 2009 | 03:27 AM
  #163
JasonZ-YA's Avatar
JasonZ-YA
lol.....okay cool....thanks for the laugh..
-J
Old Sep 25, 2009 | 10:46 AM
  #164
o2sys's Avatar
o2sys
Question:
19x10 ET20 wheels IF you add a 25MM spacer whats the new offset? -5MM? So this would stick out of the rear fenders???
Old Sep 26, 2009 | 11:40 AM
  #165
stinky350z's Avatar
stinky350z
hi everyone i was wondering if someone could help me please i bought 10mm project kicks spacers for my rears n i put them on the oem studs were sticking out too far out , and so it was hitting my wheel and i wasnt be able to tighten with the lug nuts , am i doing something wrong or what , thanks everyone
Old Sep 26, 2009 | 11:46 AM
  #166
JasonZ-YA's Avatar
JasonZ-YA
your wheels must be aftermarket, because stock wheels would work....
That being said - RE-read post 5-9 again!
you dont have enough GAP in your wheels to run that THIN/thickness (10mm) of spacer. a 10mm spacer means you have 15mm of OEM stud still sticking out, which means you need a GAP of greater that 15mm on your wheels "in-between" your lug mounting holes.
REREAD post 5-9 .....go outside and measure your wheels..... and then get back to me
-J
Old Sep 26, 2009 | 11:50 AM
  #167
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by o2sys
Question:
-5mm yes. and yes.
best suggestion is for you to mount the wheels and measure to the fender from the "face of the wheel" then buy "that dimension" thickness spacer....(so long as it will work with your wheel gap - see post 4) and install on your car.
if you like it, cool........./the end...
if not, buy bigger or smaller, its an aesthetics thing for most peeps.......so im assuming so for you with out any further details given..
-J
Old Sep 26, 2009 | 11:52 AM
  #168
JasonZ-YA's Avatar
JasonZ-YA
stinky350z, get on YM and i can help ya more if you need..
-J
Old Sep 26, 2009 | 12:03 PM
  #169
vispre's Avatar
vispre
Originally Posted by JasonZ-YA
Ok,
FRONT 19x9 +47
REAR 19x9 +30
Thanks guys.
-J
wow those stock offsets are atrocious. i think i would need a plus 50 mm spacer in the front at least.
Old Sep 26, 2009 | 12:07 PM
  #170
JasonZ-YA's Avatar
JasonZ-YA
lol...wait till you find out the weight of them.........
if given to me, i would sell them...
-J
Old Sep 26, 2009 | 12:29 PM
  #171
vispre's Avatar
vispre
-J
by the way you say that, i dont even wanna know.
I went to the nissan dealership today to pick up his temp tag (my buddy just bought a Z yesterday) and i was looking at the 370's. I saw the window sticker saying something about "RAYS forged wheels". how could forged wheels (esp made by rays) be anything but light?
Old Sep 26, 2009 | 12:47 PM
  #172
JasonZ-YA's Avatar
JasonZ-YA
SEE post #9
https://my350z.com/forum/wheels-and-...s-on-350z.html
-J
Old Sep 28, 2009 | 07:56 AM
  #173
SlipZ's Avatar
SlipZ
question for the MOD :
what the best spacer set up for work meisters S1's on 19x9.5f +23, 10.5 r +24. I want to make it flush just right. im thinking of going with +10 all around but i cant any pics of it in that set up?..
any info is great!!
Cris
Old Sep 28, 2009 | 04:44 PM
  #174
stinky350z's Avatar
stinky350z
^ im selling project kicks 10mm spacers
Old Sep 29, 2009 | 04:02 AM
  #175
JasonZ-YA's Avatar
JasonZ-YA
any info is great!!
Cris
Sup Cris,
Like i mentioned before your best bet is to measure with the wheel on the car, get a ruler and measure off the sidewall of the tire to the cars fender line you wanna be "FLUSH" with.
From there order your spacers.
once again, if you get spacers that are 10mm, then that means your gonna be left with 15mm of oem spacer protruding past the mating surface of your spacer on a set of "spacers with studs" Thus, also requiring your work meisters S1's to have the GAP inbetween the lug holes
OR
your gonna need to pull your oem studs and install longer studs to install "spacers that require longer studs"
-J
Old Sep 29, 2009 | 04:03 AM
  #176
JasonZ-YA's Avatar
JasonZ-YA
post them up in the private classifieds....
they will sell fast...
-J
Old Sep 29, 2009 | 09:29 AM
  #177
SlipZ's Avatar
SlipZ
Sup Cris,
OR
-J
Thanks- J
Old Oct 6, 2009 | 02:50 AM
  #178
Darkness75's Avatar
Darkness75
Hi all ,
i have 20f-25b spacers and i still have vibration . i did check wheel balance all good
i think i`ll remove them if i`m the only one with this issue
Old Oct 6, 2009 | 06:55 AM
  #179
JasonZ-YA's Avatar
JasonZ-YA
Originally Posted by Darkness75
Hi all ,
ya dude, something isnt right.........for one, spacers must be installed incorrectly or something for there to be vibration! are the spacers center hole the same diameter as the hub?? 66.1mm???
only thing i can figure that a set of spacers can cause vibrations is "INSTALLATION" if the spacers arent seated to the hub face due to the hub hole in the spacer being the wrong size, etc???
Where did you get the spacers?? are they for the Z?
do you have hubcentric rings...
ALSO:::
Remember, read this LINK BELOW -- if you are NOT using hub rings - you can have a misaligned/non-centered wheel mounted causing the vibrations...The issue here isn't the spacers but YOU and YOUR INSTALLATION!!!
SEE HERE- https://my350z.com/forum/7388163-post81.html
-J
Old Oct 7, 2009 | 10:42 PM
  #180
Darkness75's Avatar
Darkness75
they are brand new V2 Ichiba Spacers for 350Z
and if you please what do you mean by :
-J
any pics ?
