Widening Stock Wheels
After quite a long time of deliberation I have decided I want to keep my stock rims, because I like the style of my "08 rims. However in the near future I will need wider rims/tires due to a substantial power increase. I was wondering what your guy's oppinions are on getting stock rims widened?
Here is the place I'm thinking of going with:
http://www.weldcraftwheels.com/
Well it looks like it's going to be approximately $200 a wheel to widen them 2". So that comes to a total of around $800 plus shipping. Seems like a good deal for a set of 18x10 front and 18x10.5 rear.
You will also need spacers to do it properly to set the offset back to stock or to a more aggressive stance. A 25mm rear spacer would pretty much return the offset back to +30. So with that added in your looking at $1100 total. I nice set of Rota can be had for that, a few more pennies will get you Enkei.
That is a valid point, however I can choose to widen any part of the rim, so with a carefully thought out widening position I can have a flush offset. Also I want to stick with 18's and I havent found any good looking 18's that are wider than 9.5".
Ideally you would add width equally to inner and out to do it right. But with the spoke design all width would be added on the inside and spacers will be needed.
Does it look safe to you?
I can see how you could possibly widen a wheel in a more safer way, but it is probably not worth the hustle - I doubt anyone except top wheel producers have proper equipment to do so.
It will be a unique wheel, but difficult to do well. Is the new wheel out of round? Can it be balanced?
widening wheels is done on motorcycles all the time. In fact I did it to my Yammi Warrior. It worked great, right up until I got run off the road and went over a curb. Ended up with a nice, almost square wheel. In the cycling world, widened factory wheels cannot/are not sold with DOT certification.......IE...."for track use only". I'd spend the extra clams and get aftermarket wheels.
Well....I have a G35 Coupe with the ray's 19". I really like the wheels, in fact I paid $1000 to get them polished. Going FI next month and thought I'd widen the rears out to help with traction. I need new rear tires anyway. SO I'm only lokking at about $500.
Wish I could widen them in a way that I wouldn't need the spacers but can't visualize a way that would work.
Thinking of going to 10" rears but want to make sure and go to a size that has a couple options on tire manufactures. Guess I'll start researching tire/wheel info....
Thanks
Thanks
Thanks
Thanks
If you still doing this then just move the back wheels to the front and widen the front, that would be better idea.
