Official Aggressive Wheels & Fat Tires Thread
Old Feb 19, 2012 | 04:44 PM
  #3101
Ak48z's Avatar
Ak48z
Originally Posted by SoCal07HR
Thanks for the correction, I don't understand why you are trying to hate. Because I said 8.5 inch wide wheel is too small for this thread? Well it's true.
You can fit a 255 on a 8.5" wheel... so lets go ahead and take out 1/3 of the entries on this thread and throw them out.
Old Feb 19, 2012 | 05:08 PM
  #3102
SoCal07HR's Avatar
SoCal07HR
Okay sounds good.
Old Feb 19, 2012 | 05:21 PM
  #3103
Ak48z's Avatar
Ak48z
Lol thanks for playing.
Old Feb 19, 2012 | 05:57 PM
  #3104
ronn1's Avatar
ronn1
I'm running them on my car and I can tell you they are slightly small for the 11 inch wide wheel. A 275 will be small for that wheel in this thread. I'm not trying to argue with anyone, but a 265 on a 10.5 inch wheel and a 275 on an 11 are too streched for this thread.
BTW, good choice on those F14's Ron, gonna look good on your Z.
Hear ya...
looking forward to F14s
Old Feb 20, 2012 | 03:31 PM
  #3105
SoCal07HR's Avatar
SoCal07HR
Another of mine. 18x10 +25 with 275/35-18 front, 18x11 +30 with 295/35-18 rear. Wheels are CCW C2K Corsair.
Old Feb 20, 2012 | 03:46 PM
  #3106
ronn1's Avatar
ronn1
Looks good!
Old Feb 20, 2012 | 03:47 PM
  #3107
Waiz's Avatar
Waiz
Nice wheels!
Old Feb 20, 2012 | 05:33 PM
  #3108
Kirbaaybaayy's Avatar
Kirbaaybaayy
Old Feb 20, 2012 | 05:57 PM
  #3109
Noor93y's Avatar
Noor93y
What would you guys recommend for a 20x12 inch? Im not good with offsets. If i wanna do 20x9 and 20x12 what offsets would be reasonable? im looking at the forgestar cf5. as far as tires im having a hard time finding anything all season over 295. im wanna go for 255 30 20 and 305 30 20
Old Feb 20, 2012 | 06:36 PM
  #3110
Kirbaaybaayy
to make the 20x12 fit in the rear you will prolly need atleast +10 offset. but idk for sure
Old Feb 20, 2012 | 07:10 PM
  #3111
jarrodh77's Avatar
jarrodh77
To fit a 12" rear without hellaflush camber, there is a very narrow window of offsets. Anything higher than about a +33 will hit the suspension, and anything lower than about +29 will be poking. You'll need a fender roll no matter what.
Old Feb 20, 2012 | 07:21 PM
  #3112
IsDatIt's Avatar
IsDatIt
ANyone Know If A 325/30/19 will fit on my 19x11 +25?
I currently have a 285/30 and its way to stretched for my taste.
Fenders Rolled and mild Drop on Tanabe's GF210'S?
Old Feb 20, 2012 | 07:35 PM
  #3113
SoCal07HR's Avatar
SoCal07HR
Sounds a lot more like you're talking about an 11 inch wide wheel. A 12 inch wheel will poke without hellaflush camber no matter what. I just clear the suspension and will be perfectly flush once I adjust my camber down to about -1.3 and I'm running an 11 inch wide wheel.
Old Feb 20, 2012 | 07:37 PM
  #3114
IsDatIt's Avatar
IsDatIt
How Much More Room do u have on the outside? Tire Wise? Because i wanted to Fit a 325/30 on my 11+25...
Thanks
Old Feb 20, 2012 | 07:39 PM
  #3115
NA&CH's Avatar
NA&CH
Looks awesome Kirbaby!! Love those rims.
Chris
Old Feb 20, 2012 | 07:49 PM
  #3116
SoCal07HR's Avatar
SoCal07HR
To answer your question about the 12 inch wide wheel, I am running an 18x11 +30 in the rear and here is a pic of my inner clearance:
Even though it looks like there is lots of room my wheel just contacted my damper at about -2.8 camber when going through a dip. Had to reduce my camber. To run a 12 inch wide wheel you will need a bit of camber if you have any kind of fat tire on your car.
A 12 inch wide wheel has the same inner clearance as you can see in my pic above at +17.
Run a higher offset at your own risk, mine contacted my damper.
At that offset your wheel will be poking for sure, my recommendation to you is to just run an 11 inch with wheel if you want to run fat tires. 12 inch wheels are for hellaflush setups on the Z.
Old Feb 20, 2012 | 08:19 PM
  #3117
ronn1's Avatar
ronn1
Even though it looks like there is lots of room my wheel just contacted my damper at about -2.8 camber when going through a dip. Had to reduce my camber. .
Looks like I'll have room to spare with my new 18X11 +23 with 275/40s.
Old Feb 20, 2012 | 09:51 PM
  #3118
terrasmak's Avatar
Dam, that is like freaking close to perfection. Awsome.
Old Feb 20, 2012 | 10:30 PM
  #3119
SoCal07HR's Avatar
SoCal07HR
That means a lot to me coming from you sir. Perfection will be when I get new tires and run 295/30 and 315/30.
Old Feb 20, 2012 | 11:14 PM
  #3120
ronn1's Avatar
ronn1
I guess you're commenting on the 275s with 11s....
Yes..but within accepted manufacturer's tire specs. I have 245/40s up front on 9.5s....pretty much the same *stretch*..fits nice and handles very well.
I have 275s on my current set up and they're NEW, so a swap makes sense. I don't want 285/35s (too short). My best bet would be 285/40s...but they're not readily available in as many brands.
BTW...here's a pic (NOT MINE!) of 275/35/18s on 18X11 (front pair) and 315/30/18 on 18X12.5s (rear pair). Same relative *stretch*, but the 315s are *approved* to only 11.5"
