Official Aggressive Wheels & Fat Tires Thread
Old Apr 14, 2013 | 06:23 PM
  #4641
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Originally Posted by STL 350Z
Would that poke out past the fender or be pretty flush and ok with a fender roll or would I be best off with a 295/30.
BTW thanks for your help.
You'll be out a 5mm (0.02") more than me. Since you're on coils I say go with the 305/30 and make height adjustment.
Old Apr 14, 2013 | 07:41 PM
  #4642
Bmurray350z's Avatar
Bmurray350z
Why did you need to switch exhausts 03?
Old Apr 15, 2013 | 02:15 AM
  #4643
03threefiftyz's Avatar
03threefiftyz
Weight.
Old Apr 15, 2013 | 07:10 AM
  #4644
STL 350Z's Avatar
STL 350Z
eeeeeexcellent.
Old Apr 15, 2013 | 08:20 AM
  #4645
Robert_K's Avatar
Robert_K
Didn't Go Cheap
eeeeeexcellent.
Might want to start considering a set of F&R SPL camber arms. They really help with getting that perfect alignment. I ordered mine from Import Parts Pro.
Old Apr 15, 2013 | 09:16 AM
  #4646
03threefiftyz
Because grip....
Old Apr 15, 2013 | 10:05 AM
  #4647
scotts300's Avatar
scotts300
Had a few wondering what the static ride height was....
Switching exhausts on site...trailer is like a lift!
What do you use for front and rear tow attach points?
Old Apr 16, 2013 | 08:17 AM
  #4648
03threefiftyz
LCA's and toe buckets unfortunately. That said, I have probably towed 6000mi in the past few years and it has not bent the arms or pulled the alignment yet...
Old Apr 16, 2013 | 11:20 AM
  #4649
scotts300's Avatar
scotts300
Amazing pics.
I have been going to the tow hook in the front, and LCAs in the rears. Wasn't sure what others were doing, and have been considering going through the wheels.
Old Apr 16, 2013 | 12:15 PM
  #4650
brandon3434's Avatar
brandon3434
Good god 03threefiftyz, you win.
Old Apr 16, 2013 | 01:59 PM
  #4651
KingBaby's Avatar
KingBaby
Hardest Setting
last picture made me moist
Old Apr 18, 2013 | 09:04 AM
  #4652
hove24's Avatar
hove24
Just got some rims, 18x8.75 +20 for the front and 18x9.75 +20 for the rear. Looking to join this fat tire community, any recommendations on tire sizes? Stock suspension, fenders aren't rolled.
Old Apr 18, 2013 | 09:54 AM
  #4653
terrasmak's Avatar
Ditch the XXR junk and buy wider wheels.
Old Apr 18, 2013 | 10:30 AM
  #4654
hove24's Avatar
hove24
I wasnt looking to spend a lot of money on rims, between the conditions of the roads and the fact that its my dd, its not worth it to me. Any recommendations on some tire sizes would be appreciated though, thanks.
Old Apr 18, 2013 | 06:53 PM
  #4655
Robert_K's Avatar
Robert_K
Didn't Go Cheap
That should be a major factor on buying a quality set of wheels.
EDIT: Oh and we don't **** around with 8" wide wheels. Come back when you're ready to run 10", 11" and 12" wide wheel. Than we can give you tire recommendations. Till than listen to the counter guy at Discount Tire. LOL
Old Apr 18, 2013 | 08:14 PM
  #4656
mr. sparco's Avatar
mr. sparco
Last pic is awesome, need me some CCWs.
Old Apr 24, 2013 | 09:46 AM
  #4657
KingBaby's Avatar
KingBaby
Hardest Setting
Old Apr 24, 2013 | 10:15 AM
  #4658
STL 350Z's Avatar
STL 350Z
What's your size's king?
Old Apr 24, 2013 | 11:19 AM
  #4659
KingBaby's Avatar
KingBaby
Hardest Setting
18x9+5 275/35
19x10-3 285/35
currently trying to save up to buy stock fenders off this wrecked Z to clean up my rear...
Old Apr 24, 2013 | 11:30 AM
  #4660
the3kgt2's Avatar
the3kgt2
I currently have staggered Enkei RPF1's in this setup:
Front: 18x9.5+15 with RS-3 265/35/18 tires
Rear: 18x10.5+15 with RS-3 285/35/18 tires
I used to run NT05 275/40 up front and 295/35 in the rear without rubbing. Since my fronts are worn out and rears are practically new, I was thinking about swapping the 285's up front and try some R888 305/35/18 for the rear. My front fenders are cut and my rears are rolled. My camber is set to -2.0 front, -1.5 rear and I'm lowered just over 1". Think I have a shot?
