Official Aggressive Wheels & Fat Tires Thread
Old Aug 15, 2010 | 07:02 PM
  #1021
scotts300's Avatar
scotts300
Originally Posted by dkmesa350z
you fit 285 on a 10.5 up front? You run a fair amount of neg camber though, don't you? I am afraid that I would rub like crazy with a 265/35 on a 10.5 +15, so I'm still looking for a staggered set.
Yup, with 3.2* camber up front. I'm actually more worried about the rear than the front, as the front is tucked in rather nicely. I haven't done an event with them yet, but I put about 50 street miles on them without an issue at any corner. I think the 265 will be absolutely fine.
Old Aug 15, 2010 | 07:23 PM
  #1022
vashuba311's Avatar
vashuba311
Originally Posted by ComeBack
This is more of what this thread needs...
what exhaust is that? looks like hks but more slanted... thanks
Old Aug 15, 2010 | 09:42 PM
  #1023
cliffrlp's Avatar
cliffrlp
Injen SES with Ti tips.
Old Aug 16, 2010 | 06:52 AM
  #1024
dkmesa350z's Avatar
dkmesa350z
Yeah, with -1.6 camber and a 265, the 20mm more than makes up for 1.6 more positive camber...wouldn't ya think?
Old Aug 16, 2010 | 07:27 PM
  #1025
350Z_Al's Avatar
350Z_Al
R :19x9.5 +10 (after 15mm spacer) 285/35/19
A couple more recent pics of mine:
Pic doesn't quite do it justice, there is less than 1/8" between the tire and fender lip...
Old Aug 16, 2010 | 09:38 PM
  #1026
ComeBack's Avatar
ComeBack
^^ What is your rear camber at? I am almost those same sizes and i am trying to decide on spacers.
Old Aug 17, 2010 | 05:20 AM
  #1027
350Z_Al's Avatar
350Z_Al
I think between -3 and -3.5 degrees. I'll check my alignment sheet when I get home.
Fenders are rolled, pretty well to the point of being pinched. Fenders are also pulled slightly.
I had to do a little bit of clearancing with a grinder and hammer on the inside of the fender where the fender meets the rear bumper. Nothing major, and not visible from outside the wheel well. It still rubs that spot a little bit on a big compression of the rear suspension (dip in the road for ex.), but not too bad.
Old Aug 17, 2010 | 07:43 AM
  #1028
scotts300's Avatar
scotts300
Hmm, I'm not sure. Remember, however, that it's only 10mm on the outside, with the other 10mm on the inside. That's 1cm. . . 0.4". . . tiny. . . Do you have 1/2" of clearance currently?
Old Aug 17, 2010 | 02:51 PM
  #1029
dkmesa350z's Avatar
dkmesa350z
I rub on the screw on the fender liner, but if I removed that I might have that much clearance. Roughly how does camber equate to clearance for the average lowered Z? 1.6 degrees of camber will put you about 1/2 inch closer to rubbing?
Old Aug 18, 2010 | 07:19 AM
  #1030
scotts300's Avatar
scotts300
The 285/30 is over 1/2" shorter than the 265/35, so that screw may not be an issue. I think some simple geometry, which I can't do right now, would answer the question of how much further the top of the wheel sticks out when comparing 3.2* of camber to 1.6* of camber.
Old Aug 18, 2010 | 08:13 PM
  #1031
350Z_Al's Avatar
350Z_Al
Didn't make it home till late late last night... I am at -3.3 degrees in the rear.
Old Aug 18, 2010 | 08:24 PM
  #1032
ComeBack's Avatar
ComeBack
Thanks I am still debating on either 15 or 20mm spacers in the rear. I think I might do 15's then I will be close to your stance but with a little higher camber probably like -2.5ish.
Old Aug 21, 2010 | 08:17 AM
  #1033
BMR's Avatar
BMR
Nothing too aggressive, but definitely got some fatty tires...
19x9.5 - 275/30/19
19x11 - 305/30/19
Old Aug 25, 2010 | 01:32 PM
  #1034
scotts300's Avatar
scotts300
Another pic of the 18x10.5 +15 with 285/30/18 x 4
Old Aug 25, 2010 | 07:21 PM
  #1035
512_Z's Avatar
512_Z
Thumbs up
Correcting
Old Aug 25, 2010 | 07:37 PM
  #1036
03threefiftyz's Avatar
03threefiftyz
Originally Posted by 512_Z
Anyone intersted in tires I have a pair of Michelin Riken tires brand new 100% thread will ship. PM for pics...
asking $115 each OBO
275/35/18
^in before infraction/deletion.
Old Aug 26, 2010 | 03:26 AM
  #1037
dkmesa350z's Avatar
dkmesa350z
Thanks! And that Z is a whole lotta WIN.
Old Aug 26, 2010 | 06:40 AM
  #1038
scotts300's Avatar
scotts300
Thanks!
Old Aug 26, 2010 | 06:49 AM
  #1039
dkmesa350z's Avatar
dkmesa350z
Thanks!
Does that Z belong to you also? Its amazing. I want a mod/ spec list!
Old Aug 26, 2010 | 06:52 AM
  #1040
vex008's Avatar
vex008
sorry gotta ask...is this car's name bruce?
was going to paint my race car that color - thats why i ask.
