' WHEELS & TIRES '!!!
Old Jul 30, 2002 | 06:56 AM
  #121
jrreed350togo's Avatar
jrreed350togo
TXStyle we need your help man....Put it in plain english for us.
If we use 9.5 for the rear will the offset be +30 or +38?
Old Jul 30, 2002 | 10:53 PM
  #122
TXSTYLE's Avatar
TXSTYLE
I was afraid of this!!! What this means is that with the NISMO (or others) suspension setup, their struts & coilovers are thicker than stock! This means that you must go with a lower offset wheel: +25, +30! Which means the wheel will come out further from the wheel well. Unfortunately I can't think of any wheel on EARTH that has that low of an offset! And guess what? That means you'll ABSOLUTELY have to run spacers! They're not that bad though. I just personally don't like to fool with them. Well this indeed poses some interesting challenges for even me. I know for a fact that my aftermarket wheels have +35 offset front and rear, so guess what I probably won't lower my car. But on a positive note, my wheels are 19's so I may come out just right.
Old Jul 31, 2002 | 12:21 AM
  #123
jrreed350togo
So what you're saying is YES.
We can get 275/40/18 9.5 with the +30 offset on the rear for those of us not fooling around with the suspension. Are you sure that spacers are necessary? It's really confusing cause they make it seems as if the +30 is with their suspension only. What my wheel guy told me was the distance from +30 to +33 was like stacking 3 CD together. It's not that much difference but we want to get it right the first time. I'm really concerned about clearing the brakes and suspension. I know the Z will be able to take the wider tire but this wheel crap is too complicated. I need that little guy from "The fast and Furious".
Old Jul 31, 2002 | 05:28 AM
  #124
jrreed350togo
TXSTYLE after reading you reply again...I think I finally get it. If you're staying with factory suspension you can go with the +38 offset. If you use Nismo Suspension or any other you have to go with the +30. Why do they say 8.5? Is it because this is the width that comes standard?
Old Jul 31, 2002 | 10:44 PM
  #125
TXSTYLE's Avatar
TXSTYLE
Correct! And yes, it appears that the "factory" rim width must be 8.5 which is actually pretty decent.
Old Aug 1, 2002 | 02:29 AM
  #126
jrreed350togo
Ok for all looking to put some fat rubber on the back and front you now have the numbers needed. Time to place those orders.
Recap:
***With factory standard suspension set-up***
245/40/18 8.5 +30 Offset FRONT
275/40/18 9.5 +38 Offset REAR
If going with Nismo suspension follow the guide.
Old Aug 2, 2002 | 10:43 PM
  #127
NittoZ's Avatar
NittoZ
Charter Member #65
TXSTYLE: I am going with 19's also. What size tires are you going with? I dont want the tires to stick out at all or maybe just a little. I am planning on going with 8.5's all the way around. Any suggestions on tire size?
NittoZ
Old Aug 3, 2002 | 10:18 PM
  #128
TXSTYLE's Avatar
TXSTYLE
NittoZ
Sounds like a winner! I'd say the perfect setup for you is either: 245/40/19 or 255/40/19 And you have SEVERAL brands to choose from!
http://www.tirerack.com/tires/Compar...tButtonName=Go
Old Aug 4, 2002 | 07:23 AM
  #129
Traffic's Avatar
Traffic
OK, now let me see if I have this correct: since the NisMo suspension is wider than the stock suspension, it requires a lower offset, meaning I have to run slimmer wheels? And does anyone think I can fit an 18x10 out back?
Old Aug 10, 2002 | 11:30 PM
  #130
TXSTYLE's Avatar
TXSTYLE
One of the 3 rims I am considering!
And as seen on this Heavily Modified NSX!
Old Aug 11, 2002 | 10:12 PM
  #133
TXSTYLE's Avatar
TXSTYLE
Originally posted by Amused
not a bad first post, huh?
I was trying to post that damn image yesterday, but it would not save properly? How'd u do it?
Old Aug 11, 2002 | 10:58 PM
  #134
TXSTYLE's Avatar
TXSTYLE
Thumbs up
I posted up several good choices for the viewing masses: https://my350z.com/forum/showthread....8940#post38940
Old Aug 12, 2002 | 07:35 PM
  #136
TXSTYLE's Avatar
TXSTYLE
I did a screen capture:
1) Alt+Print Scrn
2) Open Photoshop
3) Paste
4) Trim
5)
Ahhhhhhhhhhhhhhhhhhhhh! Clever.
Old Aug 12, 2002 | 09:46 PM
  #137
shoalhaven's Avatar
shoalhaven
Cool Stock Wheels
TXSTYLE --
I am getting the Touring model with manual trans. I seem to recall that the front wheels will be changed to 18 x8's. If so, and if I put on 245/45 tires up front, (same as on the rear), will I end up with poorer handling than if I left the 225/45's up front?
Old Aug 13, 2002 | 12:18 AM
  #138
TXSTYLE's Avatar
TXSTYLE
Default Re: Re: Stock Wheels
Originally posted by VQracer
Yes you would since they (Nissan) already engineered the suspension for a staggered setup. That is why the aftermarket wheel packages always place the wider wheel in the back along with wider tires. I would recommend doing the staggered setup like the factory.
Victor
Yeah. What he said!
Old Aug 13, 2002 | 10:00 PM
  #139
Ari1856's Avatar
Ari1856
Default I disagree
You car will handle better without the staggered setup. Wider tires in the front will help dial-out understeer.
Old Aug 13, 2002 | 11:27 PM
  #140
TXSTYLE's Avatar
TXSTYLE
Default Re: I disagree
Greetings Ari1856, and welcome! Everyone is entitled to an opinion here, BUT! All I will say to your opinion is "It is no coincidence that most if not all Great Sports Cars come with a -staggered- setup!" Lamborghini, Ferrari, Porsche, Aston Martin, shall I continue? Believe me, it's for a reason.
