Will I be able to put my tire pressure sensor back on..........
Old Oct 8, 2003 | 07:36 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Question Will I be able to put my tire pressure sensor back on..........
Hi, My Z peopel!~
will I be able to put the stock tires pressure sensor back on after i install the after market rims, or it will be no longer useful? and if i can, how? is it hard to put it back on, and also , do I need a alignemnt after I install my after market wheels, thanks
Old Oct 9, 2003 | 06:57 AM
zwindsor's Avatar
zwindsor
Twisty addict
Whether the sensors will fit your new wheels, depends on the wheels...some you can some you can't. If not you can attach them with a steel band concept that was posted here earlier. Do a search.
No alignment needed with new wheels.
Old Oct 9, 2003 | 07:36 AM
Apexi350z's Avatar
Apexi350z
Charter Member #50
what rims are you getting? post pic if you can, that way we can try to determin if the tps will fit.
Old Oct 9, 2003 | 11:02 AM
Todd@ProDyno's Avatar
Todd@ProDyno
I believe Ive seen him talk about Axis wheels...
Old Oct 9, 2003 | 01:06 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Smile
Axis supermesh 19inch
picture are below
http://www.spyeng.com/spy/supermesh.html
Old Oct 9, 2003 | 01:57 PM
MSOsr's Avatar
MSOsr
Probably need to use steel bands to secure the TPS on the wheels.
Old Oct 9, 2003 | 03:29 PM
abogada001's Avatar
abogada001
I used 175lb 60 in. tie wraps with an custom aluminum bracket and some double sided tape. Works perfectly so far. Doi a search to get a general idea of how it works.
Robin
Old Oct 9, 2003 | 06:46 PM
jimmy71's Avatar
jimmy71
Default tps install
i have axis seven mods. and the tps will mount just like stock. it is as simple as unscrewing it of the stock wheels and screwing it on the new ones. just make sure you put the same sensors back in the same corners. such as right front to right front.good luck
Old Oct 9, 2003 | 06:59 PM
HaNkYs_Z's Avatar
HaNkYs_Z
Default Re: tps install
Thanks for the info,
couple more questions, what is the tps looks like, can you post a picture, b/c i thought the tsp is mounted inside the tires or something, isnt? correct me if i am wrong, and can i ask you what size of tires are you running on your Axis wheel, and what is your offset on you front n back, and which brand of tires did you buy, thanks
etkms
Jun 19, 2022 06:30 PM
Vigman
Nov 17, 2015 04:34 AM
rizzla
Sep 29, 2015 03:58 PM
Calinismo350z
Sep 14, 2015 04:04 PM
speedsniper
Sep 14, 2015 08:46 AM
