spacers on wheels
Old Nov 11, 2009 | 08:39 AM
whodey_15's Avatar
whodey_15
Default spacers on wheels
hey all... I just purchased a new set of tires and wheels on my 03 z and was wondering what you all mite think would be a good size spacer to give it a little meaner stance. The size is 8.5 all the way around. Thanks for the help!
Old Nov 11, 2009 | 09:02 AM
Ilike350Z's Avatar
Ilike350Z
25mm front ,30mm rear
Old Nov 11, 2009 | 09:06 AM
DavesZ#3's Avatar
DavesZ#3
Moved to the proper forum
Read the Spacer FAQ at the top of this forum... https://my350z.com/forum/wheels-and-tires-60/
Old Nov 11, 2009 | 09:13 AM
scotts300's Avatar
scotts300
You can't make this suggestion without knowing the offset and what size tires he plans to run on the wheels. For example, if they are 18x8.5 +12, you could not run a 25mm nor a 30mm spacer.
OP - what is the wheel offset, and what size tires are on them?
Alternatively, you could them on, measure the clearance, position them how you'd like them, and order appropriate spacers for what YOU consider "mean stance".
Old Nov 11, 2009 | 09:21 AM
There is one right answer? Come on use a tape a measure the distance between the tires and fenders. How far do you want to move the wheels? 10 mm? 20 mm? You can best decide.
Old Nov 11, 2009 | 01:04 PM
jeremyh007's Avatar
jeremyh007
i was also considering spacers on my 07. what are some good places to get em? looking probably at 20, 25mm
Old Nov 11, 2009 | 05:19 PM
B2autodesigns's Avatar
B2autodesigns
Vendor - Former Vendor
I have them in stock!!! Pm me if you would like some pricing.
Thanks
Charles
Old Nov 11, 2009 | 05:56 PM
Viggy75's Avatar
Viggy75
i have an 08 with ichiban spacers 20mm front 25mm rear... my tire size in front is 245/45s on 18s rears are 275/45 on 18s the spacers do just fine... its also dropped 1.6 inches on tien springs... your welcome if that helped with the decision that theyll fit just fine..
Old Nov 11, 2009 | 06:02 PM
JasonZ-YA's Avatar
JasonZ-YA
start here....
/thread...
Obadabot
Jun 18, 2023 11:31 PM
