Duhh!!!!
Old Nov 12, 2009 | 01:37 PM
Ret.A10Pilot's Avatar
Ret.A10Pilot
Default Duhh!!!!
Hello guys,
I know there is a link somewhere here, I am now fully retired and now getting started on my Z !
I am looking to get a set of wheels and tires for it
2005 350Z Roadster White
Since i live in Pothole city Illinois, I would love to get a set of 18" wheels, but feel I will end up staying with the 17", Would like any suggestions as to what tire or wheel set that would enhance the stance and looks, with out having to give up my tpm or any fender rolling etc
Basically looking for what size widths i can get away with? by using the 17" or 18"
if you can paste link or direct info?
Thanks all
Old Nov 12, 2009 | 03:41 PM
sdZ33's Avatar
sdZ33
I would suggest a 17x9 or 17x10 +20 or around for the offsets... 45 series for the sidewall height.... If you want 17's.... my .2 cents
Old Nov 12, 2009 | 04:20 PM
druz13's Avatar
druz13
https://my350z.com/forum/showthread....1&postcount=45
this post might be helpful.
p.s. id say go with 18's
Old Nov 12, 2009 | 04:23 PM
ChanceWarren's Avatar
ChanceWarren
Nah, stick with 18s. You'll be fine; but I'd advise against 19s (although you're probably smarter than that anyway). ^--this dude's width/offset suggestions are good too. But don't do 17s...
ed- the other guy.
Old Nov 12, 2009 | 05:34 PM
WhiskeyHotel's Avatar
WhiskeyHotel
I think you'll be fine with 18's as above. 245/40 on the front; 275/40 or 275/35 on the rear would be a good starting point.
You flew Hogs? That's one bada$$ aircraft.
Old Nov 12, 2009 | 08:34 PM
Ret.A10Pilot
Default Thanks
Yes, I feel although the slowest one in the Force, the most feared....
If anyone out there has ever heard the rip from the GAU30.....'
In real life, it will raise your neck hair.....
Raised more than that firing that bad puppy......
I will most likely try the 18s , But when you guys talk about offset and spacers
do i order wheels that way, or is there a kit??
Thanks for the non informed........
.....oops , Forgot,
The tire sizes are listed as such, is there a rim size i will need to stay with also....
Sorry bout all the repeated questions, just checking and double checking...
Old Nov 12, 2009 | 11:37 PM
sdZ33's Avatar
sdZ33
OP, decide if you want 17" or 18"... You'll probably end up going with 18...haha.... now decide the widths and offsets of the wheels... that will determine your tire widths... It does sound really confusing but you'll get get it when you do your research... GL
Old Nov 13, 2009 | 12:41 AM
1GR8350Z's Avatar
1GR8350Z
I would also go 18's and you also need to decide if you want to go with a staggered set-up or the same width all round. The offsets also determine the size of the lip and most set ups have the wider wheels in the rear with the larger lip
Old Nov 17, 2009 | 07:36 AM
ChanceWarren
I don't think there's any question he should get a staggered setup. Going uniform all around on a Z is like... going uniform all around on a Porsche.
Old Nov 17, 2009 | 12:35 PM
Spike100's Avatar
Spike100
Hi,
I would go with 18” wheels (I’m assuming that you ask about street driving). 18” wheels definitely handle better and feel better in corners than 17”. I have both sizes, but I only use the 17” wheels for winter driving.
Here is an easy and reliable size-upgrade:
  • Front: 8.5” x 18” wheels with 245/40-18” tires
  • Rear: 9.5”x18” wheels with 275/40-18” tires
If you are ordering new wheels, here’s another setup that looks sharp (and keeps the same siewall height for fronts and rears:
  • Rear: 9.5”x19” wheels with 275/35-19” tires
An offset of 30 to 22 eliminates rolling your rear fenders even if you drop the car about ½”. I would get wheels with the offset you want rather than adding the complexity and cost of spacers.
Some members prefer wider tires with a 16 to 18 offset, but that may require rolling your fenders. But then again, if you really want a “flush look,” the only way to do this is rolling your fenders.
--Spike
thecrow1414
North Central
54
Jun 30, 2009 07:12 AM
thecrow1414
North Central
226
May 7, 2008 03:17 PM
thecrow1414
North Central
23
Apr 24, 2008 05:23 PM
thecrow1414
North Central
May 1, 2007 03:07 AM
03mEWuse350Z
Apr 26, 2007 09:55 AM
