spacers?
Old Oct 17, 2003 | 01:38 PM
fresno350's Avatar
fresno350
Question spacers?
anyone use spacers with their wheels to make them more flush with the fenders? i have 18" stock wheels, and i want to make them potrude out more. how far can i go without rubbing the wheelwell on a bump? how much are they, and where can i get them...also, what is involved in installing them? ive heard of people using 15mm and 25mm.
Old Oct 17, 2003 | 02:04 PM
MY350Z.COM's Avatar
https://my350z.com/forum/showthread....threadid=45875
Old Oct 17, 2003 | 02:23 PM
fresno350's Avatar
fresno350
thanks......so, what did you end up using on yours? is 25mm a safe bet to use all the way around? did you find a place that sells the spacers and bolts you need in a kit? thanks
Old Oct 17, 2003 | 02:34 PM
MY350Z.COM's Avatar
I have yet purchased any spacers.
Victor
Old Oct 20, 2003 | 12:00 PM
zstricklen's Avatar
zstricklen
Fresno, I did considerable research before ordering my spacers for my Rays Tracks. First, be aware that there is a lot of junk out there.
1. Your spacers should be forged, not cast. Mine are forged from 6061 6T billet aluminum by Fred Goeske of Design Deluxe (wheeladapters.com) I guess stainless could be okay, too, but heavier.
2. Your spacers should be hub centric AND wheel centric. Hubcentric simply means the spacer has a recess that fits perfectly onto the hub; wheel centric means there is also a protrusion, or lip that fits perfectly into the wheel. In other words, the spacer effectively becomes a section of the wheel and a section of the hub.
Some economy spacers do not have these features. These spacers cannot work properly because they require the studs to center the wheel. Studs cannot center a wheel and the load ends up being tranferred to your studs. This is the cause of the vibrations you may have heard discussed, among other problems. Hub/wheel centric spacers transfer loads directly to the hub. Not only do they not cause vibrations, but they can be an effective fix for existing vibrations that may have been caused by improperly fitted wheels or spacers.
How thick your spacers should be depends, of course, on what wheels (and tires) you plan to install and how much you want to increase your track. I was thinking 25mm rear and 15mm front, but Fred encouraged me to go to 20mm on the front. I have not received them yet. I'll let you know how it goes.
BTW, these are not cheap, but neither is your car or your new wheels.
Old Oct 20, 2003 | 12:14 PM
Audito350Z's Avatar
Audito350Z
Hey zstricklen.... what are you doing for longer wheel studs? Any source other than Courtesy Nissan Parts and their NISMO studs?
Thanks,
PeteH
Old Oct 20, 2003 | 12:29 PM
fresno350's Avatar
fresno350
im using the stock 18 inch performance model tires
Old Oct 20, 2003 | 12:35 PM
fresno350's Avatar
fresno350
oh your from dayton zstricklen? cool. i grew up in hamilton/fairfield area. until i moved away in 93 in the marines. been in cali ever since. how is it back there?
Old Oct 20, 2003 | 01:10 PM
zstricklen's Avatar
zstricklen
Audito...Don't need longer studs. These spacers, or adapters, as Fred calls them are engineered to fit onto your hubs and then use the same studs you now have. Everything you need comes with the spacers. (Or I hope to Hell it does...As I said, I haven't received them yet.)
Fresno, Yeah, I live in Centerville. I was at Jungle Jim's in your old stomping grounds the other day. BTW, if you're going to stick with the stock performance wheels, just measure from where your tire is now out to where you would like it to be, then get spacers of that thickness.
(Do you remember or have you heard of Fearless Fred Goeske from the 60s and 70s? That's the guy. A real pro. He was turning 357 mph in 4.2 seconds in the early 80s in his Hydrogen Peroxide Rocket Car. Apparently the car was banned from NHRA events because of the speeds he was reaching and the associated liability.)
Old Oct 20, 2003 | 09:47 PM
N74DV's Avatar
N74DV
Fred made mine also. I've had mine for over a year.... 12K miles and no troubles. Excellent spacers!
Old Oct 20, 2003 | 11:02 PM
350ed's Avatar
350ed
Professional
How much did you guys pay for your custom Goeske spacers? TIA.
Old Oct 21, 2003 | 01:00 AM
zstricklen's Avatar
zstricklen
There were some other considerations in my deal, but if you get spacers like mine I believe they will cost about $65 per wheel for hubcentric spacers and an additional $20 per wheel to make them wheelcentric. Tell him Charlie from Dayton sent you; maybe Fred will send me a Snickers bar or something.
Old Oct 21, 2003 | 07:40 AM
N74DV's Avatar
N74DV
mine were about $300 shipped
I had to find open ended 12x1.25 mm nuts locally as Fred did not send them with.
He did send the 1/2" nuts for the spacer studs.
Old Oct 21, 2003 | 04:01 PM
noel's Avatar
noel
Default Re: spacers?
i had mine special made for my bigbrake kit.you want to have hub centric ones & w/studs..so important to have hubs on there as well.they call it adaptors w/hubs..the place is called rusell here in torrance,kali.went to the machine shop where they make it.big azz shop.they took my wheels down for measurement.they are very professional.it only took them 2 days to make all 4..amazing.they are light too.here's some pics.
Old Oct 21, 2003 | 04:05 PM
noel's Avatar
noel
this 1st 2 pics are front.thicker than rear.
Old Oct 21, 2003 | 04:12 PM
noel's Avatar
noel
Rear,notice they stick out more.doesn't rub @ all.
Old Dec 25, 2003 | 06:07 PM
Blue Batmobile's Avatar
Blue Batmobile
Inventor
Blue Batmobile
I had new wheels installed a week ago. I had the car aligned a few days after getting my springs installed. I noticed a slight vibration at freeway speeds. I guess I'll be need hubcentric and wheelcentric spacers?
Bat™
Old Dec 25, 2003 | 10:17 PM
supra crazy's Avatar
supra crazy
Wow im looking into spacers too and was wondering if these are good or should i order some from the company u guys got yours from?
Link!!!!!!
Old Dec 27, 2003 | 08:48 AM
MotiCarmona's Avatar
MotiCarmona
the easiest way and much safer way to go would be to just get custom made adapters , spacer are way too dangorous and adapter would do the job ad even better , get adaters and wheel locks and u got wht uwant and no way for the wheel to fall of like it could with spacers
Old Dec 27, 2003 | 05:56 PM
jeffrey's Avatar
jeffrey
I'm going to be getting the 25mm H&R spacers to make room for big brakes.
They look like an excellent design to me:
This site has a lot of good info as well:
http://www.livermoreperformance.com/...20Spacers.html
