Wheel width Question Please
Old Oct 20, 2003 | 12:28 AM
4WSboy's Avatar
4WSboy
Default Wheel width Question Please
I am going to upgrade from 17" to 18".
Any suggestions regarding a "sensible" width (Its a daily driver)
Does the car "tramline" if it gets too wide?
I was thinking 8" and 9" respectively..Thanks
Old Oct 20, 2003 | 04:05 AM
FLY BY Z's Avatar
FLY BY Z
Old Oct 20, 2003 | 04:13 AM
lowrider's Avatar
lowrider
Depends on what tire sizes you want to run. With 8.5 and 9.5, you'd run 245/40's and 275/40s respectively. If you choose to run 8 or 8.5 all the way around, you run 225/45 and 245/45 or 245/40 and 255/45. So again, wheel width depends on tire size. Both sizes must be decided jointly.
Lou
Old Oct 20, 2003 | 04:23 PM
350Z-RED's Avatar
350Z-RED
go with 8.5 front 9.5 rear
for tires, if your going with 19's front 245/35/19, rear 275/35/19
Old Oct 20, 2003 | 07:28 PM
johnsZ's Avatar
johnsZ
tires are sized roughly to the rim width. there will be a recommendation from the tire maker about the range of rim widths in relation to the tire tread width- too small and the tires will bulge and be unstable, too wide and the bead wont seal right, and might peel off under hard cornering. talk to a knowledgable tire dealer first.
Old Oct 20, 2003 | 07:43 PM
ares's Avatar
ares
Veteran
8.5/9.5 with 245/275 are an extremely common size on this forum.
I can tell you I have them, I find they offer plenty of traction(with good tread you can only break traction with a hard launch, chirping gears is difficult unless the tires are cold)
no tracking that Ive noticed.
Old Oct 21, 2003 | 01:18 AM
4WSboy's Avatar
4WSboy
Thanks a lot.......What are the pros and cons regarding having the different widths front and back? as opposed to the same?
Thanks
Old Oct 21, 2003 | 03:20 AM
rktjhn's Avatar
rktjhn
If "tracking" means wandering, drop the tire pressure in the back 2# and it won't do that anymore
Old Oct 21, 2003 | 07:26 AM
ares's Avatar
ares
Veteran
good question, I dont think there are any pro's. they are supposed to be taller that I know. but wider... for drag racing it would make sense, but the difference should be much greater, no reason to have the drag of a 245 in front in a straight line.
and for turning, itll cause understeer due to the increased traction in back on an already understeer prone car.
you dont have to go wider in back, it does look cool tho.
Old Oct 22, 2003 | 12:31 AM
4WSboy's Avatar
4WSboy
Sorry. What will cause understeer? Having less width on the front?
I didn't quite follow you .......duuuh
Most guys seem to have 1/2 " difference between f and r.
Here in Aussie the "Touring" has the 1/2" diff in the 17's but the "track" has 18X8 all around.
Hence my confusion when considering 18's for my "touring"..
which has 17's now
Thanks
Steve
issyz
Jul 2, 2017 03:04 PM
hulkout
Apr 28, 2017 09:00 PM
HoBrahYouStink
Jun 24, 2016 10:58 PM
Mattg350z
Oct 2, 2015 06:51 AM
