Square Wheel & Tire Setup Questions
Old Jul 3, 2011 | 09:13 PM
  #61
NA&CH's Avatar
NA&CH
I am running a 10.5 square with a 265(all four). Tires are slightly stretched. I am planning on rolling/pukking the rear and adding a 20mm spacer to the rear. The front might need a spacers but nothing more then 10. It sticks out with an eibach drop.
Let me know what you end up doing.
Chris
Old Jul 3, 2011 | 09:35 PM
  #62
dreamspeed's Avatar
dreamspeed
245s on a 10.5 will be horribly stretched....unless thats the look you are going for
Old Jul 3, 2011 | 10:17 PM
  #63
shaddy-z.'s Avatar
shaddy-z.
Chris
I'm going to be lowered on coils. I already have rear camber arms, so I'm not sure if a pull will be necessary for me if I set the correct amount of camber will it? I won't be adding spacers up front but hopefully a 20 mm out back.
Yes I am going for a stretched look. I understand a lot of people don't like it and they're entitled to their opinion! But I like the look myself
Old Jul 20, 2011 | 03:57 PM
  #64
kevincat's Avatar
kevincat
Default square setup on staggered rims?
current setup
19x9.5 245/35/19
19x10.5 275/35/19
so my rear tires are pretty much done for and im in the market of new tires. Current im sitting on coilovers and my rear rubs a bit on a moderate fender roll. I was contemplating on getting 245/35 for the rear, but i dunno if i should run a square setup on staggered rims.
is there anything i should be concern about?
i was also thinking about getting 225/45 on the front and move the 245/35 to the rear as my front tires are practically new. but that would be too much trouble as my tech already have a problem installing my tires with my tpms installed on a deep dish rim.
Old Jul 20, 2011 | 05:45 PM
  #65
You intend to put a 245 mm tire on a 10.5 inch wheel? That will look cool.
Old Jul 20, 2011 | 09:48 PM
  #66
Waiz's Avatar
Waiz
Roll your fender more or dial in more camber rather than purchasing a narrower tire.
Old Jul 21, 2011 | 08:58 AM
  #67
scotts300's Avatar
scotts300
I would never put a 225 on a 9.5" wheel, nor a 245 on a 10.5" wheel. There is a thread for those evil thoughts though.
Old Sep 13, 2011 | 06:52 PM
  #68
co_dot_jp's Avatar
co_dot_jp
Default 19x11 Square Setup?
Ive been looking into some wheels and i wanna get something a little different the the usually Amazing wheels ive seen on Z lately.
Avant Garde Has some Really nice sizes for price and quality.
19x11 +18 is what im thinking about but i couldn't find any good information about anyone running this size wheel up front or more aggressive.
Will it fit with the right pull, stretch ect....or is it to close to the control arm and coilovers ect?
This car seems to be doing it but no info if he did it with ease.
Old Sep 13, 2011 | 07:02 PM
  #69
ITOzann's Avatar
ITOzann
18x11 _+18 with fat tires( 275/35/18F and 295/35/18R)
seems like no prob in my opinion. You'll need camber, roll, etc...
Old Sep 13, 2011 | 07:14 PM
  #70
no vtec 4me's Avatar
no vtec 4me
i tucked rim on 19x10.5 et12 up front so you should be able to fit 19x11 no problem with the right tire size/camber/roll....i was REALLY low though
Old Sep 13, 2011 | 10:38 PM
  #71
Czarrr's Avatar
Czarrr
I can almost guarantee you that you'll need a roll.
Definitely some camber arms.
The pictured red Z doesn't look like it's pulled all too much, except the rears.
I would expect a pull on the fronts rather than the rears.
Old Sep 14, 2011 | 07:38 AM
  #72
gotboost36's Avatar
gotboost36
im running 10.5 0offset so you should be good..
Old Sep 14, 2011 | 04:38 PM
  #73
rcampbell0610's Avatar
rcampbell0610
i just messaged that guy that owns it a few days ago because i was thinking of running the same setup and he said it fit fine, he ran spacers on the rear and 255R 245F you can find the thread about those wheels a few pages back. M310s in purple is in the title. He lists the specs in there
Old Sep 14, 2011 | 06:16 PM
  #74
lgear080's Avatar
lgear080
you will completely change the drive "feel" of the car.
it will not be the same when you're done.
just a heads up. you may very well be unhappy with the results.
Old Nov 19, 2011 | 08:27 AM
  #75
Rouse350z's Avatar
Rouse350z
Default 19"x10.5" all around?
Came across some varrstoen rims on craigslist brandnew for 900, but the only problem is that they are 10.5 all around. i know they will fit in the back but what about the front? please let me know if they can fit the front and if so how can i make them fit
Old Nov 19, 2011 | 08:31 AM
  #76
Flo-ridaZ33's Avatar
Flo-ridaZ33
Superblack350z is selling TE's that are 19x10.5 +22... Yes theyll fit with light mods.
Old Nov 19, 2011 | 08:58 AM
  #77
terrasmak's Avatar
Offset is everything, need to know the offset of the wheels.
Old Nov 19, 2011 | 11:37 AM
  #78
Rouse350z's Avatar
Rouse350z
Yeah they have +22offset. And how much is he selling them for cuz I have a budget of 2000 with tires right now
Old Nov 19, 2011 | 11:53 AM
  #79
Duckeee's Avatar
Duckeee
should fit unless you have brembos.
Old Nov 19, 2011 | 12:36 PM
  #80
If you can imagine it - it has been done. Put a 255 mm tire on the front and you are good to go.
