wheel spacer installation issue
Old Apr 10, 2010 | 07:24 AM
Brrcats's Avatar
Brrcats
Default wheel spacer installation issue
I was installing my wheel spacers last night and when I looked at the stock hub ring I noticed a black (plastic?) ring on the outside of the stock metal hub ring. This black ring was preventing the hubcentric ring from lying flat against the hub, and ultimately, the wheel flat against the hub spacer. I have tried to find pictures of stock hubs to see if this ring is something that comes OEM or something that someone has put on the hub down the line (bought the car used)
I black ring was on there tight as all hell, and I wasnt sure if it was able to be removed or not.
I ended up being able to tighten the wheel down to a point where it appeared visually flush against the spacer, however I noticed that when driving, there is visually some play in the wheel.
So basically I'm wondering if anyone else has encountered this before or have any idea how to remove this black plastic ring?
I know pictures would help, but i've misplaced my camera, hopefully I've been able to describe it effectively enough.
Old Apr 10, 2010 | 08:15 AM
THe ring is designed to properly fit aftermarket wheels. I do not recall a ring with OEM wheels.
Old Apr 10, 2010 | 08:45 AM
DavesZ#3's Avatar
DavesZ#3
So basically I'm wondering if anyone else has encountered this before or have any idea how to remove this black plastic ring? .
Jerk the brake rotor toward yourself and that will cause the hub ring to slide off a little. Then you can get a screwdriver, putty knife or something else behind it to work it off that way. They can fit tight, especially if rust has built up around them and the hub.
Old Apr 10, 2010 | 09:01 AM
cheshirecat79's Avatar
cheshirecat79
Yeah, just use a little flathead screwdriver to pry it off. OEM wheels do not need this ring. If you have aftermarket wheels, put the ring on the spacer before you mount your wheels.
Old Apr 10, 2010 | 09:13 AM
Brrcats's Avatar
Brrcats
excellent, thanks for the information. I do have aftermarket wheels, so this is probably why this is there. I'll try to see if I can work it off somehow.
good thing I came back to check this, I was about to dremel the hell out of it, lol.
Old Apr 10, 2010 | 10:20 AM
myork's Avatar
myork
I wouldnt be driving around like that - its a good way to ruin your bearings or worse, have 1 or more wheels separate from the car.
Both the spacer and the wheel are not making proper contact with the hub and rotor, and the plastic centering ring will deform adding more play.
Not a good thing to have your wheels wobbling around like that, especially at speed.
Old Apr 10, 2010 | 11:24 AM
DavesZ#3's Avatar
DavesZ#3
Since you have aftermarket wheels, you'll have to pull the hub rings off, install the spacers then use the hubrings on the spacers before you put the wheels on again.
Old Apr 10, 2010 | 01:08 PM
Brrcats's Avatar
Brrcats
yeah, this is what I ended up doing. Was instantly able to tell a difference when putting the wheels back on.
I ended up using a very small screwdriver and a rubber mallet to get the ring off the hub initially. worked like a charm.
thanks for the help all
Old Apr 10, 2010 | 01:18 PM
AFD350Z's Avatar
AFD350Z
thats fire dept. mentality..lol.. if it dont come loose..break it or cut it off...not a good thing when it comes to cars
Old Apr 12, 2010 | 06:19 AM
Brrcats's Avatar
Brrcats
lol, yeah, usually things are there for a reason. Good thing it didnt escalate to that point
Old Apr 12, 2010 | 04:35 PM
Kuhan's Avatar
Kuhan
Once you take the hub rings out, sand down hubs a little, so next time you'll be able to remove the rings more easily.
EDIT: Don't the wheel spacers already have hub centric rings?
Old Apr 12, 2010 | 08:07 PM
Thermal1's Avatar
Thermal1
If they are hubcentric spacers, they will be flush with the hub on the car, and would probably be centric to factory wheels, but since he is apparently using aftermarket wheels, they would not be hubcentric on the wheel side.
...or wheelcentric I guess might be the term.
Old Apr 13, 2010 | 05:22 AM
Brrcats's Avatar
Brrcats
yeah, the spacers came with the hub centric rings, which were metal, then there was the black plastic ring that was on the hub. davidv posted a picture of it. this ring goes around the hubcentric ring when using aftermarket wheels.
Old Apr 13, 2010 | 09:04 AM
scotts300's Avatar
scotts300
Ah, would have been no big deal - they're only 6 or 8 bucks to replace.
Old Apr 13, 2010 | 10:49 AM
Brrcats's Avatar
Brrcats
good lookin out, its too bad too, I was really looking forward to dremeling
aarrgghh
May 1, 2022 11:04 AM
m_0g
Jun 3, 2021 10:05 AM
DarkCreep
Oct 17, 2015 11:50 PM
seagrasser
Oct 11, 2015 03:27 PM
