Will this tire throw my VDC or slip light?
Old Apr 24, 2010 | 03:01 PM
03performance's Avatar
03performance
Default Will this tire throw my VDC or slip light?
A 285/35/19will it work?....I have a 19" wheel that is 9.5 inchs wide. i have a 275/30/19 on it now and i have no problems. will this little increase in the sidewall give me any problems?
Old Apr 24, 2010 | 03:56 PM
R350nate's Avatar
R350nate
why would it give you a problem? the only thing you will have to worry about is fender rubbage. but theres no way 10mm of tire will throw codes
Old Apr 24, 2010 | 04:13 PM
DavesZ#3's Avatar
DavesZ#3
What size is on the front?
Did you check the Top 100 Questions thread, there's a post in it that explains how to determine the proper F/R stagger.
My guess is that it's going to cause problems. 285/35 is over 1½" taller than the 275/30. Assuming you already had some F/R stagger, this is going to make it even more. The recommendation is to stay between 0.25 and 1" of stagger.
Old Apr 24, 2010 | 07:07 PM
terrasmak's Avatar
If you have a proper front tires, 275/35 or 285/35 is the proper rear tire.
Old Apr 24, 2010 | 07:13 PM
Is the front tire size a secret?
Old Apr 24, 2010 | 09:49 PM
scotts300's Avatar
scotts300
Need to know front tire size to help.
Old Apr 25, 2010 | 01:41 AM
03performance
Sorry, the front is a 245/35/19 on a 8.5" wide rim. Any help will be great thanks!
Old Apr 25, 2010 | 03:28 AM
Tire circumference is a difference of 4.2 percent. I do not like it.
Old Apr 25, 2010 | 04:56 AM
DavesZ#3's Avatar
DavesZ#3
The answer is in this thread...
https://my350z.com/forum/4936171-post42.html
245/35 up front works with 275/35 out back.
Old Apr 25, 2010 | 10:24 AM
03performance
so they do work for sure without it throwing any kinda SLIP light or anything? I dont wanna mount them then just have to take them off right away
Old Apr 25, 2010 | 10:39 AM
DavesZ#3's Avatar
DavesZ#3
By "they" do you mean 245/35 285/35? Yes, they will probably work but the OD difference is a little high (1.1"). You might have VDC kick it at odd times, it just depends on the tolerance of your car.
The preferred pairings are 245/275 or 255/285 as those keep the stagger under 1".
Old Apr 25, 2010 | 11:22 AM
dkmesa350z's Avatar
dkmesa350z
Thanks for the question that you could have answered about one thousand times over from one simple search. 285/35 is more correct to stock diameter than 275/30.
Old Apr 25, 2010 | 02:37 PM
DavesZ#3's Avatar
DavesZ#3
I'm somewhat surprised you're not already having problems with 245/35 and 275/30. With that setup your fronts are taller than your rears and that almost always causes VDC/TCS problems, especially on the older models like the 03. Accelerating into turns, highway speeds, etc. should be causing the Slip light to appear.
Old Apr 25, 2010 | 02:56 PM
ComeBack's Avatar
ComeBack
What if you had a 275/35/19 square setup? Would that cause any problems? I would think not since all wheels and tires are moving the same rotation at the same rate.
Old Apr 25, 2010 | 03:19 PM
DavesZ#3's Avatar
DavesZ#3
Normally, it doesn't cause a problem. I have used a square setup for autocross and track use for years and rarely have TCS/VDC kick in when driving to/from events. Some cars appear to be more tolerant than others with little or no stagger.
Uriyo_
Sep 8, 2021 08:46 AM
350z82
Oct 1, 2015 06:25 PM
