XXR Wheels Thread
Old Apr 14, 2014 | 05:31 PM
  #1881
mr. sparco's Avatar
mr. sparco
That's the spirit, never give up. Some 16" wheels fit over the DE brakes, that are very light and inexpensive, but would that be a good reason to do it? lol
Old Apr 14, 2014 | 07:01 PM
  #1882
Spike100's Avatar
Spike100
Yup… sometimes we pick a tire/wheel setup for the wrong reasons.
I notice that 350z drivers who track use 18” or 17” wheels, but 19” wheels are a rare choice.
And… it seems the better a car performs on the track, the shorter the wheel diameter, but the wider the wheel and it’ corresponding tires
- Formula 1 racers use 13” wheels
- Stock car racers use 15” wheels
Old Apr 14, 2014 | 07:21 PM
  #1883
350ZZJoe's Avatar
350ZZJoe
While I fully understand and agree with the concept of lighter wheel = better performance, I highly doubt that was OP's intention when he bought a cheap, heavy wheel to replace a good looking, quality OEM wheel.
So that discussion hardly seems relevant in this instance.
Old Apr 14, 2014 | 07:32 PM
  #1884
Spike100's Avatar
Spike100
The stats for the XXR 526 are actually quite good:
XXR 526 17x19” wheel: 22.5 lbs
XXR 526 17x10” wheel: 23lbs
Old Apr 14, 2014 | 07:45 PM
  #1885
dmill's Avatar
dmill
They look good man. Just lower it about 2.5 inches to fit the car. It will look a lot better.
Old Apr 14, 2014 | 07:49 PM
  #1886
dmill's Avatar
dmill
well maybe not that low. 1 pic looks like you got a lift, and the 1 of your rear wheel looks like its lower. It could just be uneven ground.
  #1887
mr. sparco's Avatar
mr. sparco
That's a lot of sugar coating but we should keep it real. Sometimes members buy what they can afford but at the same time it's not always in the right direction. Modding for the sake of being different isn't always an improvement. As long as the OP is happy that's all that matters even if we don't all agree with his purchase.
Old Apr 14, 2014 | 08:36 PM
  #1888
350ZZJoe's Avatar
350ZZJoe
Well the Enkei RPF1 in comparable size weighs about 16.75lbs and 16.9lbs so I don't know if I'd say these XXR wheels are quite good.
I don't know many other wheel specs but I can't see those weights for a 17inch wheel being really great. I'd think they are average/heavy at best.
Obviously you get what you pay for (to an extent) but I would say these wheels are heavy. If OP had of gotten them in 18inch they would be even heavier. But let's be clear, in 18inch variety, I think they look quite good on the 350Z. I just think the weight argument is silly considering the given situation.
Old Apr 15, 2014 | 02:11 AM
  #1889
JMSpeed's Avatar
JMSpeed
^^ Any reason you didn't go with 275/40/18 for your rears?
Yes. Was looking for a setup I could easily rotate. The spacer will make the rear look more full as opposed to the tire.
Old Apr 15, 2014 | 10:24 AM
  #1890
hellman_x's Avatar
hellman_x
Tragedy into a worse tragedy. Should've stuck with oems.
Old Apr 15, 2014 | 10:33 AM
  #1891
hellman_x's Avatar
hellman_x
But then again… Formula 1 cars have 13” wheels with tires way over 300mm wide. For reasons that go back to Jah70’s arguments. --Spike
The only reason f1 has kept the dinky wheel ratio is because of cost. New wheels means more research and the f1 teams would have to redo their whole suspension setup. Larger wheels means less play in the sidewalls which means better steering.
Old Apr 15, 2014 | 02:44 PM
  #1892
Jah70's Avatar
Jah70
With the amount of money teams like Ferrari generates I'm sure money isn't an issue to do the research. And what about NASCAR, WRC, FIA GT1, FIA GT2 and Super GT?
Old Apr 15, 2014 | 03:26 PM
  #1893
Spike100's Avatar
Spike100
XXR 526 17x9” wheel: 22.5 lbs
Enkei 17x9” wheel: 16.4 lbs
Enkei 17x10” wheel: 17.2 lbs
The difference is 6 lbs. That difference is huge for the track and insignificant for the street. I know my choice when running on the track.
So… There you have it.
Old Apr 15, 2014 | 03:41 PM
  #1894
Spike100's Avatar
Spike100
Wrong… wrong… wrong… I don’t know what else to say. Cost is NOT an issue here.
The companies spend so much money, but not on stuff like wheels and tires that the manufacturers compete to provide to teams.
Old Apr 15, 2014 | 04:17 PM
  #1895
SR71's Avatar
SR71
Lead Super Moderator
Still waiting for the OP to post up the excellence.
Old Apr 15, 2014 | 05:10 PM
  #1896
Jah70's Avatar
Jah70
op's Z kinda looks like it has one of those billy goat beards or a weird looking chin strap. I think that is where the excellence comes in?
Old Apr 15, 2014 | 06:51 PM
  #1897
hellman_x's Avatar
hellman_x
The don't run 13" as far as I know. I'm not sure what you trying to get at.
A simple tire size change means whole suspension geometry change, hours upon hours of real track testing, and the tire manufacturer constructing a new tire. That plus the new engine regulations would be a tight squeeze on the budget. Just trying to have an constructive argument.
Anyhow back to OP, rotational mass and unsprung weight sounds nice but if you are not tracking the car, you are going in the wrong direction with tire size. I wouldn't track with reps though.
Old Apr 15, 2014 | 07:03 PM
  #1898
mr. sparco's Avatar
mr. sparco
Didn't know we had so many F1 industry experts here. How did you guys get that far off topic? lol
Old Apr 15, 2014 | 09:35 PM
  #1899
SR71's Avatar
SR71
Formula One wheel sizes have been fixed at 13 inches (330mm) for two decades
Old Apr 16, 2014 | 02:42 AM
  #1900
Jah70's Avatar
Jah70
Besides F1, some cars in FIA GT use smaller diameter wheels than their stock counterparts and so do rally racing. That's what I'm getting at. But op's not tracking is car so who cares. Whatever tickles his pickle.
