Need advice asap
Old Sep 3, 2010 | 08:57 AM
bslagle3's Avatar
bslagle3
Default Need advice asap
So long story short i have a slashed tire and need to get my Z to a shop. Would it be a bad idea to put the spare donut tire on the rear with the differential? Will it heat it up too much since the tire diameters will be off? Thanks for the help
Old Sep 3, 2010 | 10:28 AM
Mr. D's Avatar
Mr. D
Why have a spare tire if you couldn't use it?
Old Sep 3, 2010 | 10:42 AM
SSZVirginia's Avatar
SSZVirginia
Use the spare. Do you think it was designed for a front tire flat only?
Old Sep 3, 2010 | 10:45 AM
winchman's Avatar
winchman
I suppose you could put a good front tire on the back, and put the spare on the front.
Either way, don't drive faster than they recommend, and get the regular tire fixed as soon as you can.
Old Sep 3, 2010 | 10:54 AM
JET MECH's Avatar
JET MECH
I get what your asking about the VLSD potentialy being damaged, all of the above responders obviously do not. Yes i would swap out one of the fronts to the rear and put the donut spare on the front. I am assuming you have 19" or 20" wheels on your z for you to be concerned about this. If you have rims with the OEM rim diameter than it would not matter.
Old Sep 3, 2010 | 11:27 AM
DavesZ#3's Avatar
DavesZ#3
You're not supposed to drive on a spare more than 50 miles or 50mph. The owners manual doesn't say anything about VLSD problems.
Old Sep 3, 2010 | 11:28 AM
bslagle3's Avatar
bslagle3
Ya I've asked around to some of the Nissan dealerships and some are telling me not to use the spare on the rear and some are telling me that it's ok to use the spare only for a low speed and short distance. I currently have the 18" track wheela on it. I just ordered a set of 20" matte black Giovanna kilis that are on the way.
Old Sep 3, 2010 | 11:32 AM
bslagle3's Avatar
bslagle3
Thank you guys for the help... One of the Nissan service managers was telling me to not put the spare on the rear with the differential even with stock wheels. We all know that they are frequently wrong so I just wanted to double check with you guys. I only have a 15 mile drive to the shop I am taking it to.
Old Sep 3, 2010 | 11:33 AM
winchman's Avatar
winchman
Why would you assume we didn't "get it"? Maybe we did, but didn't mention it because it makes no difference as long as you follow the OM recommendations for low speed operation and getting it fixed ASAP.
Old Sep 3, 2010 | 11:45 AM
JET MECH's Avatar
JET MECH
You need to calm down buddy and not get your panties in a bunch.
Old Sep 3, 2010 | 12:44 PM
Spike100's Avatar
Spike100
You can safely run the spare on the rear. As Dave mentions, keep the speed low. If you have TCS or VDC, turn this OFF.
--Spike
________________________________________
EDIT: Someone above mentioned wheel size. The wheel size does not make any difference. You can run the spare tire a short distance at lower speed on any corner of the car regardless of your wheel size (17, 18, 19, or 20).
etkms
Jun 19, 2022 06:30 PM
liqalu04
Jan 2, 2022 12:58 PM
LunchBox20
Oct 20, 2015 10:22 PM
