19" wheel offset fitment question
Hi
I have a question about 19" rim.
will 19x9.5+29 front and 19x10+10 rear fit a 2004 350z?
Thanks.
Thanks.
Use a offset calculator to compare your current wheels to the new wheels. With the new dimensions, check the car with a tape. Do you clear the suspension, brakes calipers and fenders? Reference: http://www.1010tires.com/WheelOffsetCalculator.asp
for front wheel,
if I compare original stock setting 18x8+30 to 19x9.5+29
inner clearance is 18mm less (the inside of the wheel to the strut housing)
would that be a problem?
I might have a 5mm spacer.
As a reference, 255/35/19 front and 285/35/19 rears get you pretty close to OEM tire outer diameter to keep vehicle dynamic system (and wheel gap) happy. And it just so works out that there is a 30mm width difference between front and back.
seagrasser
Oct 11, 2015 03:27 PM
