Varrstoen Wheels Thread
Old Oct 10, 2013 | 11:39 AM
  #1621
BadBlu-Z's Avatar
BadBlu-Z
Originally Posted by Waizzz
There are literally hundreds of examples of this basic setup in the Varrstoen thread
Did you already look there?
Ive looked at a lot of set ups. But what im seeing is most people running +12 or +15 with the wheels cambered in. Im looking to go LOW on coils with 0 camber. So I really just needed to know if a +22 would fit without rubbing or if i needed to go +30 to be safe and add spacers if needed.
Old Oct 10, 2013 | 11:42 AM
  #1622
BadBlu-Z's Avatar
BadBlu-Z
Originally Posted by SamPappas
Wheel Specs and offset?
Old Oct 10, 2013 | 11:52 AM
  #1623
Bmurray350z's Avatar
Bmurray350z
If you're going to go reallll low like you say, then +22 and +30 will be way sunken in. I'd go +12/+15. You may even needs spacers with that depending on how low you go.. The wheels naturally camber in as you go lower..
Old Oct 10, 2013 | 12:34 PM
  #1624
BadBlu-Z's Avatar
BadBlu-Z
I know they will naturally camber in. But I have rear adjustable camber arms ill be installing, so when i get coils and lower it i will also be adjusting the camber back to 0 front and rear. which will make the +12/+15 stick out im assuming, and i wont be able to tuck the 285 rear without rubbing. And by real low, I dont mean slammed to the ground, But i do want to go much lower than a set of springs will go. And i might have the rear set a little higher to make the nose dive a little for that "hot rod Muscle" stance.
Old Oct 10, 2013 | 09:55 PM
  #1625
SamPappas's Avatar
SamPappas
Lol I wish my camber arms would take me back to zero..
Old Oct 11, 2013 | 08:16 PM
  #1626
Kevin Perez's Avatar
Kevin Perez
Default Rims not clearing Brembos
Hey guys, i bought some Varrstoen ES2's (19/9.5 Front & 19/10.5 Back +22 Offset all around) for my track edition Z i tried them on today and realized it didn't clear with my Brembo brakes.. My question is would spacers fix this problem and if so what size spacers do i need. 10mm? and would i need them all around. Sorry if its a noobish question i tried searching it up and i couldn't find much.
Old Oct 11, 2013 | 08:19 PM
  #1627
Bmurray350z
Should have done research before buying! the +12 clears brembos. 10mm will fix your problem. You could also try a 5mm spacer if you have someone local that has one... Would save you from having to put extended studs in the hub, etc.
Old Oct 23, 2013 | 11:32 AM
  #1628
SamPappas's Avatar
SamPappas
idk how i missed this. 19x10.5/9.5 +2R +22F 245/35/19 225/35/19
Old Nov 11, 2013 | 06:30 AM
  #1629
Stinky EK's Avatar
Stinky EK
Anyone with a 19x11 front wheels at least with a 255 tire?
I want some ES6 but it seems to me that the 19x9.5 +15 ES6 wheels leave quite a little gap so probably a 19x11+25 would fill that?
Sadly no 19x10 which IMO would me perfect for front without excessive stretch
So again, anyone here with 19x11 +25 (F) / 19x11 +15 (R)
Old Nov 13, 2013 | 08:50 PM
  #1630
sanji1's Avatar
sanji1
Default varrstone es1
so Im getting some varrstone ES1's 19x9.5 front with +12 and 19x11 rear with +15...what kinda tires should I run and what MM spacers should I use I just want a flush maybe a lil over flush look car will only be lowered 1/2" to 1" from stock not going to droped look more function over form???
Old Nov 13, 2013 | 08:56 PM
  #1631
Bmurray350z
I'd do 255/35 and 285/35. no spacers needed with those offsets and tire sizes.
Old Nov 13, 2013 | 08:58 PM
  #1632
Neeko94's Avatar
Neeko94
you dont think thatd be looking a little stretched??
Id say 275/35 F and 295/35
Old Nov 13, 2013 | 09:06 PM
  #1633
Bmurray350z
Depends on the tire brand really... i had 19x9.5/11 +12/+15 with 245/275-35 and it was perfect. so 255/285-35 would look good imo.
  #1634
Calinismo350z's Avatar
Calinismo350z
if your thinking on lowering the car the tires you have in mind^. are going to rub. I'm running running 245/285. same size 9/11 and they look good.
Old Nov 14, 2013 | 06:56 PM
  #1635
J 0 K 3 R's Avatar
J 0 K 3 R
Originally Posted by ughhson
19x9.5 -8 ET fronts
19x11 -5 ET rears
215/35/19 Falken Azenis
245/35/19 Federal 595ss
[IMG]<a href="http://s319.photobucket.com/user/supaman2975/media/IMG_20130916_113812.jpg.html" target="_blank"><img src="http://i319.photobucket.com/albums/mm450/supaman2975/IMG_20130916_113812.jpg" border="0" alt=" photo IMG_20130916_113812.jpg"/></a>[/IMG]
wow. nice man, super clean. diggin the white on red.
Old Nov 16, 2013 | 08:34 AM
  #1636
2dazz's Avatar
2dazz
That car looks amazing! is that Megan racing single tip?? I have the dual set up on mine.....think I can convert it without changing the complete system?? was thinking the y-pipe would be the same.....
let me know if you could.
thanks!
Old Nov 20, 2013 | 11:29 AM
  #1637
skoke70's Avatar
skoke70
Default help with offset
Ok, I might have ruined my rim according to the tire tech at sears? Going to have it looked at rim repair shop.
My current set up is varrstoen ES3 19x9.5 +22 offset front (245/35/19 tires)
the rears are 19x10.5 +20 offset with 275/35/19" tires.
Called Varrstoen for a replacement and they told me that the won't be getting any of the 19x9.5 +22 offset for a long time if ever? Sounds like they might be discontinued? They do have 19x9.5 +12 on sale, so i could buy a set.
My Q is, how funny Would it look to have +12 offset in the front with +20 offset in the rear? would I rub with 245/35/19 tires?
Thanks
Old Nov 20, 2013 | 11:32 AM
  #1638
travlee's Avatar
travlee
Master
the fronts would poke out... do they have something between the two?
  #1639
Waiz's Avatar
Waiz
That is fine, if you have Brembos it won't work with that offset in the front but otherwise it will be fine
Old Nov 20, 2013 | 11:33 AM
  #1640
RUNWDVL's Avatar
RUNWDVL
I would do a square set up. But 12 is fine.
