spacer question
Old Oct 23, 2010 | 03:37 PM
350zspl's Avatar
350zspl
Default spacer question
what mm spacer can you run with factory studs and have enough threading for the lug to safely fasten
10 mm
20 mm
30 mm
what is the thickest ?
Old Oct 23, 2010 | 03:42 PM
TheFarmer's Avatar
TheFarmer
None. Get a spacer/adapter with correct threads added.
Old Oct 23, 2010 | 03:53 PM
350zspl's Avatar
350zspl
so even a 5mm spacer will not work safely and leave enough thread on the stud for the lug nut to fasten properly
Old Oct 23, 2010 | 03:55 PM
TheFarmer's Avatar
TheFarmer
You've been here since 2006. Search.
Old Oct 23, 2010 | 04:04 PM
350zspl's Avatar
350zspl
thank you
Old Oct 23, 2010 | 04:09 PM
KornerCarver's Avatar
KornerCarver
10 mm
20 mm
30 mm
The stock lug nuts are 25 mm long. Basically, you might be able to get away using 5 mm spacers. Anything thicker and I think you are asking for trouble. Just get the spacers with the built in lugs and you should have no problem.
Old Oct 23, 2010 | 04:14 PM
350zspl's Avatar
350zspl
korner carver
thank you for the reply
you are right
i actually saw the 1st sticky in the wheel and tire section dedicated to spacers
and it did answer my question
thank you for taking 1 minute to assist me on a question that has been asked millions of times
Old Oct 23, 2010 | 04:23 PM
TheFarmer's Avatar
TheFarmer
Darn! I only had 45 seconds.
Old Oct 23, 2010 | 04:36 PM
DavesZ#3's Avatar
DavesZ#3
All this is already covered in the FAQ sticky at the top of the forum.
https://my350z.com/forum/wheels-and-...er-thread.html
Old Oct 23, 2010 | 05:14 PM
Agree.
None. I do not want the wheels to fall off the car. Not cool.
Old Oct 23, 2010 | 05:44 PM
terrasmak's Avatar
Only if your running 25mm spacers, all others get the spacers that come with the proper studs (ie Ichiba V1)
Old Oct 24, 2010 | 08:43 AM
cuhristiann's Avatar
cuhristiann
I got a 50mm(2inch) adapter. That's pretty thick (that's what she said )
Old Oct 24, 2010 | 08:36 PM
ChrisR's Avatar
ChrisR
must be hellerflushed
Old Oct 25, 2010 | 06:43 PM
cuhristiann
Hahahaha you already know!
Old Oct 25, 2010 | 07:18 PM
ChrisR's Avatar
ChrisR
wish someone could tell me why my 20mm is squeking and making a clunking sound? could it be loose under them rim i looked at the rim while driving and it drives normal but clunks every rotation? =(
Old Oct 26, 2010 | 05:29 AM
350Z_Al's Avatar
350Z_Al
Take the wheel off and make sure the Project Kics lugs are tightened to their torque specs.
I've got Project Kics 15mm's. When I put them on I torqued them to their specs. After about 100 miles I pulled the wheels off and checked/re-torqued them. I've had them on for probably 5000 miles and they don't make a sound.
Old Oct 26, 2010 | 05:46 AM
JasonZ-YA's Avatar
JasonZ-YA
/thread.
-J
issyz
Jul 2, 2017 03:04 PM
