Wheels setting outside in the snow..
Old Nov 16, 2010 | 10:33 AM
joem1cha3l's Avatar
joem1cha3l
Default Wheels setting outside in the snow..
I just ordered new wheels for my Z and i have a question. They are hyper silver with a chrome lip. I have to put them on my car because i have sold my stock wheels. Should they be ok in the snow for the season? Car will have a cover on it but it does not cover the entire wheel. The car will not be driven so it would just be snow that has fallen, no salt. Im hoping they wont rust at all
Old Nov 16, 2010 | 10:41 AM
350ZTheStandard's Avatar
350ZTheStandard
They might melt, metals are like that.
Old Nov 16, 2010 | 10:47 AM
GeauxLadyZ's Avatar
GeauxLadyZ
Dude, you bought those TSW's in your other thread, didnt you?
Old Nov 16, 2010 | 10:53 AM
angelo350z's Avatar
angelo350z
On a serious note, I'm pretty sure your wheels won't be ok considering the salt they'll be exposed to. Sure they won't be driven, but salt is EVERYWHERE. Salt is evil and will find a way to f*ck up your sh*t. Maybe cover the whole wheel and tire with plastic?
Old Nov 16, 2010 | 10:57 AM
tquill's Avatar
tquill
Sitting outside in the snow?
Anyway, they should be fine. It's not as if driving them is any "safer" for wheels.
Old Nov 16, 2010 | 12:08 PM
They will get cold in the snow.
Old Nov 16, 2010 | 12:22 PM
bmccann101's Avatar
bmccann101
Default hmm
yeah it wont be fun to clean them up in the spring tho.
Why dont you clean the living hell out of them NOW and wax them up a bit with some GOOD wax.. dont leave it all on there per se, but dont remove it all.. be prepared to work like hell to get it all off inthe spring, but it will keep it from rusting a bit. .. which chrome does. Sorry, it just do, and i gotta say, if you are standing there looking at your car going.. " sh#t.... that cant be good".. then it probably is NOT good. Pretty simple premise.
If you have a Z that sits outside all winter long..you are creating:
a- an abomination
b- a sh#t ton to do when it thaws out anyways to get it running and road worth again..
c- happiness deep within me that i dont have to deal with Alaska anymore... it was 56 this morning here in AZ.
Try driving an old decked out z32 in under 40 below.. in hindsight it was truly commical.
Old Nov 16, 2010 | 01:12 PM
Spike100's Avatar
Spike100
Not to worry… You won’t have problems with the wheels on your parked car.
With this said, you do need to consider the surface on which you park your “winter-stored” car if it is stored outdoors with a cover. Here is why you need to be careful:
Any surface on which you park the stored vehicle should not absorb excessive moisture. The vulnerable part is not the wheels (which will survive well), but the undercarriage of your car and joints between the outside fender and its inner wall. Parking your car on gravel during the winter is the worst surface since it absorbs moisture and releases this to the car’s underside. Concrete is better, but also absorbs and consequently releases moisture.
A couple of solutions are thick mil construction plastic placed underneath the car (put it down and then drive the car over the covered surface) or rubberized roofing compound coating the cars parking position. It’s best if you can find a spot that is crowned so no moisture gathers on the water-proof surface you place underneath your car.
The concept is to minimize evaporation that might occur underneath the stored car. The Z is not prone to rust, but poor storage methods can overpower even a car with the best rust preventive composition.
--Spike
Old Nov 18, 2010 | 06:51 PM
themadhatterxxx's Avatar
themadhatterxxx
Does the salt really damage the clear on used on most Volks?
Old Nov 19, 2010 | 09:47 AM
Brrcats's Avatar
Brrcats
Saran wrap the entire car before the winter, problem soved
Old Nov 19, 2010 | 11:00 AM
synth19's Avatar
synth19
reading comprehension fail.... wheels will be fine covered up....
Old Nov 19, 2010 | 03:35 PM
jasabeast's Avatar
jasabeast
go out and clean them like every other week...
Old Nov 19, 2010 | 03:38 PM
Waiz's Avatar
Waiz
What is this "snow" you speak of
Old Nov 19, 2010 | 03:56 PM
sambo's Avatar
sambo
id rather leave them on jackstands. The weather will mess up your lips. Moisture and etc.
use your spare tire and other spares.
Obadabot
Jun 18, 2023 11:31 PM
