Could you reuse tires that have camber wear if you go back to oem suspension?
Old Nov 23, 2010 | 10:50 PM
noobie_1337's Avatar
noobie_1337
Default Could you reuse tires that have camber wear if you go back to oem suspension?
Just curious since a friend got rid of his tires and gave them to me but has pretty much camber wear on all of them, used around 10k miles on 1" drop. Will post pics tom
Old Nov 23, 2010 | 10:54 PM
calin's Avatar
calin
Why not wait until tomorrow to make your thread then? Nobody can give you an answer without seeing the tires
Old Nov 24, 2010 | 06:39 AM
Seriously how can I tell without seeing the tires.
Old Nov 24, 2010 | 06:46 AM
kno's Avatar
kno
can you wear shoes if you bust a toe?
Old Nov 24, 2010 | 06:58 AM
cheshirecat79's Avatar
cheshirecat79
If the wear isn't too bad you can usually just mount them on the opposing side so the camber wear is outside the tire rather than inside.
If you're looking to save money or something that's the way to go.
Old Nov 24, 2010 | 10:13 AM
terrasmak's Avatar
Yes, optimal NO. Also depends on condition.
Old Nov 24, 2010 | 12:09 PM
DavesZ#3's Avatar
DavesZ#3
It really doesn't matter what suspension the tires are on, the big question is "how much wear". If they are on the verge of cording, why even bother mounting them, they probably won't last long.
Old Nov 24, 2010 | 01:21 PM
bmccann101's Avatar
bmccann101
the issue is also if they are cording, which i bet 100 bucks they are, the pressure safety of the tire is shot. The ability for the tire to not operate in a linear fashion will also cause more premature wear, add to that no tire shop is going to remount those for you if youre talking about rotating a tire w less than 8/32 left anywhere across the tread.
I think you pretty much got your answer. We all all hateit, but theres no need to go back to stoick suspension.. just lower it correctly.
You MUST run a toe fix in the rear.. it aint camber thats killin your tires, its the toe.
parts shouldnt run more than 200 bucks, 120 lower camber bars, 80 for toe delte bolts..
i have mine droped over 2 inches and the alignment is zero rear toe, -1.5 degree camber, and i keep my tires good far far far fa...........FAR longer now.
Old Nov 29, 2010 | 07:04 PM
Never mind. I thought this was important to you. Important enough to say “thanks” or simply reply.
Old Nov 29, 2010 | 11:51 PM
BoomerZ33's Avatar
BoomerZ33
if they're directional you can't mount them on the other side. where's the pics at?
Old Nov 30, 2010 | 08:20 AM
scotts300's Avatar
scotts300
Hope you won't turn in that school essay on punctuality "tomorrow" either.
DarkCreep
Oct 17, 2015 11:50 PM
Paul.
Oct 16, 2015 07:34 PM
emooheo
Oct 14, 2015 08:58 AM
seagrasser
Oct 11, 2015 03:27 PM
