Black valve stems?
Old Jan 8, 2011 | 10:43 PM
DanZmanAZ's Avatar
DanZmanAZ
Default Black valve stems?
I want to get the "nut" for the TPMS sensors in black. does anyone sell these? or have any ideas in the best way to paint them?
Old Jan 8, 2011 | 11:01 PM
350ZTheStandard's Avatar
350ZTheStandard
Any spechul reason for painting something ONLY 1 inch long and silver to black?? What color are your valve stem caps & don't they cover up most of the valve stems??
Old Jan 9, 2011 | 12:23 AM
DanZmanAZ's Avatar
DanZmanAZ
They are silver, I just wanted a cleaner look
Old Jan 9, 2011 | 07:36 AM
You can paint them any color you want. The possibilities are endless.
Old Jan 9, 2011 | 08:42 AM
terrasmak's Avatar
Do people really care about the color of valve stems?
Old Jan 9, 2011 | 05:14 PM
zerostyle's Avatar
zerostyle
i think its 14mm...loosen it and just spray paint it. all the air pressure should keep the sensor from falling thru
Old Jan 9, 2011 | 06:22 PM
DanZmanAZ's Avatar
DanZmanAZ
I have an extra set, that I think I'm just going to paint. I think it would be a really bad idea to try it with pressurized tires.
Old Jan 9, 2011 | 06:27 PM
Waiz's Avatar
Waiz
Wait do you mean the valve stem caps?
You can just buy a black set of those from Ebay or your wheel company.
Old Jan 9, 2011 | 06:49 PM
DanZmanAZ's Avatar
DanZmanAZ
No, the nut that threads down the TPMS and actually holds the whole assembly together. Although now that you mention it, I'm going to need to some black valve stem caps too
Old Jan 9, 2011 | 07:02 PM
NoQuestionZ's Avatar
NoQuestionZ
Your whip must be UBER clean if youre cleaning it up with something small like this.... If the tire was off and I already had the TPMS taken off, i think id do it too.. Dont know if itd be a good idea to try it pressurized either..
Good luck and post pix when done!
Old Jan 10, 2011 | 04:35 AM
idrive_MD's Avatar
idrive_MD
I just took mine apart before I mounted my winter tires and painted them. The whole setup is only 3 parts, the TPMS with stem, the stem sleeve the bolts it down and the valve stem cap.
Old Jan 10, 2011 | 12:29 PM
zerostyle's Avatar
zerostyle
no at work ive taken off the top "nut" part with air still in the tires...like i said the air pressure will keep the sensor in its place
Rev_Night
Nov 7, 2020 06:00 PM
350z82
Oct 1, 2015 06:25 PM
Tochigi_236
Sep 27, 2015 03:40 PM
