Is it still considered a staggered setup?
Old Jan 21, 2011 | 11:11 AM
whitelightningHR's Avatar
whitelightningHR
Default Is it still considered a staggered setup?
Hi guys. I'm buying some wheels soon and I'm a noob to this. Never bought aftermarket before. I own a '08 Z touring. Considering buying this setup:
Rims are Rota P45R 18x9.5 all around
tires are 245/40 and 275/40
Even though the wheels are not staggered but the tires are, is this considered a staggered setup? I have stock suspension so it should all fit right? No rubbing or anything?
Old Jan 21, 2011 | 11:13 AM
calin's Avatar
calin
Ya, I would consider that staggered. And you should have no rubbing issues if you're not lowered at all.
Old Jan 21, 2011 | 11:33 AM
Barnabas's Avatar
Barnabas
National Z Club President
Its "staggered" but just incase you care the front and rear will look different because you will have a straight sidewall up front and a slight bulge on the rear.
What offsets are you getting? that is the only way to tell you if you wont rub at all.
Old Jan 21, 2011 | 11:36 AM
AdvanZ33's Avatar
AdvanZ33
Senior Super Moderator
Your tires are staggered.
Old Jan 21, 2011 | 01:22 PM
whitelightningHR
On wheeldudes website it says +20mm. Will that look more flush then factory? Here is the wheel I'm planning on getting on a PPW Z.
Old Jan 21, 2011 | 01:29 PM
stinky350z's Avatar
stinky350z
why dont you throw a 20 mm spacer in the rear it might make it look more staggered?
Old Jan 21, 2011 | 01:32 PM
calin's Avatar
calin
Old Jan 21, 2011 | 01:52 PM
Barnabas's Avatar
Barnabas
I would suggest getting a staggered setup unless you have already bought them. Liek I said before the tires will not look like the fit the same so people like me will notice and think it looks funny but to you it may not matter.
on a +20 offset you should have no problems rubbing.
I dont know what sizes Rota offers since I would never buy them but why not a 9" front rim and a 10" rear rim or even a 9" and 9 1/2" if they dont offer 10" sizes. You will be able to fit better sizes as well as make them look proper.
I currently have 9.5 front 10.5 rear net +15 offset with 255/285 tires on 19" but my next setup I think is goign to be 10 or 10.5 on all 4 corners with 285's all the way around.
You have to decide whats important to you when it comes down to it and what function you want it to perform.
Old Jan 21, 2011 | 01:53 PM
Barnabas's Avatar
Barnabas
here is what those wheels will look like... I dont remember his specs though. This is a friend of mine's Z that has since been sold.
Old Jan 21, 2011 | 02:13 PM
whitelightningHR
Would would buy a staggered set of rims but Rota doesn't make that style anyother way.
Thanks Barnabas and everyone else on your input. I appreciate it. And thank you Barnabas for the pic. I've be looking for some photos to see what it might look like.
Old Jan 21, 2011 | 02:47 PM
Spike100's Avatar
Spike100
245/40-18” F / 275/40-18” R tires on 9.5x18” wheels with a +20 offset is a very nice setup for a 350Z.
You will have great handling, and this setup will look very good. Your front sidewalls will be nearly straight and the rear will be a little bulged, so you will have a slightly different look on the fronts and the rears; but that’s not a big deal.
The +20 offset is greater than the stock +30 offset, and will put your rear tires very close to “flush.” You will not have any rubbing issues with the +20 offset unless you drop the car more than ½”.
--Spike
___________________________________
The pics posted by Barnabas (and kudos for Barnabas taking the time to do this) show a Z with a body kit. If your car is stock, it will have a more flush-look than the car in the pictures.
Old Jan 21, 2011 | 04:26 PM
Generally "staggered" is wheel width. Say front 9.0 inches rear 10.0 inches. Still its possible to do same size wheels all around with wider tires in the rear.
What this often forces you to do is stretch one tire, and "fat" the other.
350Z_Al
Oct 29, 2020 07:44 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Alexreyes
Sep 30, 2015 11:30 PM
