Who runs w/o TPMS here?
Old Feb 24, 2011 | 08:04 AM
VQpoweredZ's Avatar
VQpoweredZ
Originally Posted by phreaktor
Did all Zs come with TPMS? I have an 04 Enthusiast, and I have no idea if I have it or not.
I'm pretty sure you have it. I was looking over the sticky the other day, and it seems only the bases in 03 and 04 don't have it. Should be able to scroll through the multi-function gauge and you'll see dashes if they're not installed.
Q: I bought a (2003,2004) base model Z. Can I buy sensors or wheels from another model and put them on my car?
A: Yes you can but they won't show the pressure on the multi-function display (triple-meter) or warn you when the pressure is too low. Your car doesn't have the antenna to pick up the signals from the sensors and your computer isn't setup to display them.
Old Feb 24, 2011 | 08:10 AM
dikspiel's Avatar
dikspiel
Chestons Toilet
I run without ABS and Air Bags but my tpms still works :P
Old Feb 24, 2011 | 08:41 AM
zerafian's Avatar
zerafian
lol
Old Feb 24, 2011 | 09:51 AM
derekinthez's Avatar
derekinthez
w/o since 05, no biggie
Old Feb 25, 2011 | 09:59 AM
ocdz's Avatar
ocdz
Light comes on after a longer drive. Goes away at restart. Lose the TPMS, who cares?
Old Mar 14, 2011 | 03:22 PM
Liquidonyx's Avatar
Liquidonyx
Default TPMS
Does anyone know if running without tpms will disable the ability to shut off the traction control?
Old Mar 14, 2011 | 03:43 PM
Maxx87's Avatar
Maxx87
Don't think i have TPMS After all i don't think so with those weak Enkei CDR9's in 17 x 7,5 that came with the car...poor thing don't worry you'll get new shoes this spring!
Old Mar 14, 2011 | 05:57 PM
racer4lifegt's Avatar
racer4lifegt
I run without it. No problems here just that silly light.
Old Mar 15, 2011 | 03:22 AM
DavesZ#3's Avatar
DavesZ#3
Originally Posted by VQpoweredZ
...I've read it's illegal for places to reset the warning. ...
Originally Posted by Augustus46
... And I think it's illegal for a shop to clear a light, I think you can do it yourself though. I've actually seen something you that clears the light for you.
It's not a warning like the CEL/SES light so there is nothing to "reset" or "clear" it other than turning the car off then on again.
Shops can't clear it or turn it off. It would be illegal for them to attempt to defeat it.
Old Mar 15, 2011 | 03:26 AM
DavesZ#3's Avatar
DavesZ#3
If your older car came with 17" wheels, then no, you don't have TPMS. All Zs from 2007 and beyond have TPMS.
Two systems are not related in any way at all.
Old Mar 15, 2011 | 03:35 AM
Kwame's Avatar
Kwame
2004 Enthusiast Model 350Zs did not come equipped with factory TPMS.
Old Mar 15, 2011 | 06:21 AM
Classy's Avatar
Classy
Dumping TPSM was one of the greatest decisions I have made with my 350z, that low pressure sounds is stupid annoying.... And in the winter time in Texas temperatures go up and down so much...
Old Mar 15, 2011 | 08:48 AM
abo's Avatar
abo
TPMS Sensors gone since last year. CES light on, TPMS on. Whateve. Just lights. Hopefully one day the LED behind it burns out? lol
Old Mar 15, 2011 | 09:11 AM
DavesZ#3's Avatar
DavesZ#3
I think you are dangerously confused. People are talking about removing the sensors which triggers a warning beep after driving the car about 30-45 minutes. The low pressure warning sounds are a totally different issue. The whole reason for the push to have TPMS is that the majority of tire failures are caused by underinflation. If you were having that "problem" then you are the kind of person that needs TPMS. If you can't maintain proper pressure, you're probably wearing out your tires prematurely as well as putting yourself in danger of a blowout.
Old Mar 15, 2011 | 09:35 AM
Classy's Avatar
Classy
I think I need to explain alittle further. The temperatures would go from 60-70 degrees in the afternoon to 30ish degrees in the morning, in the morning, the sensors would read about 30 psi, but after driving a few miles and the tires warming up, they would go to 32ish psi and in the 70 degree weather would be 35. SO, my tires were properly inflated and it was just annoying to wake up every morning, go out to my car, have it make an annoying sound and then after alittle driving the pressures would be fine. I do check my tire pressures 2-3 times a month regardless of what the inaccurate tpsm's say, or the lack of them.
Old Mar 15, 2011 | 11:16 AM
BoomerZ33's Avatar
BoomerZ33
hardly ever used it. no TPMS anymore, no warning light, no problem!
Old Mar 25, 2011 | 06:06 AM
Nizmo0395's Avatar
Nizmo0395
Pull the dash, pull the bulb, tape over the hole were the bulb was.
Idiot lights are for idiots!!!
apex locator
Jul 23, 2021 02:27 AM
