Weds SA55M 18x9.0 +20 Akebono Clearance
Old Jun 3, 2011 | 03:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Default Weds SA55M 18x9.0 +20 Akebono Clearance
If anyone tell me for certain whether or not the SA55M's in 18x9.0 +20 will clear the Akebono kit for a 350Z you will seriously make my whole month.
Thanks
Old Jun 4, 2011 | 10:28 AM
datsunHEAD's Avatar
datsunHEAD
you might need a 10mm spacer
Old Jun 4, 2011 | 09:27 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Thanks, not what I wanted to hear obviously. Goddamn these akebonos are a pain in the ***.
Old Jun 5, 2011 | 10:32 AM
Chebosto's Avatar
Chebosto
y u no get OE brembos?
RR face has alot of spoke clearance...well at least for the 18x10 version...
Old Jun 6, 2011 | 07:52 AM
Jun's Avatar
Jun
Will the Akebono's fit the 18x10 +18 ones?
Old Jun 6, 2011 | 09:10 AM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Well, we can easily find out if they will fit the 18x10s if I either send Cheston the template or if he just makes one himself with cardboard :
http://www.conceptzperformance.com/i...akeoutline.pdf
I don't know why I didn't get Brembos, I saw the Akebono kit and got an Akeboner. Thought it was a great price too.
I doubt there's a problem with spoke clearance, I am 99% sure the calipers will clear the spokes on the Weds.
It's the little lip around the barrel that might not clear. (attached) That is the problem I had on my 19x9.5 +28 SF Challenge in the front, I needed to get 5mm spacer for them to clear that little lip.
I hate the spacers, I want a wheel that fits properly by itself. If I can't get it with the Weds I might as well go for the CE28N's or TE37SL's since those fit for sure. (attached)
Attached Thumbnails Weds SA55M 18x9.0 +20 Akebono Clearance-weds-sa55m-mgm.jpg   Weds SA55M 18x9.0 +20 Akebono Clearance-rays-ce28n.jpg   Weds SA55M 18x9.0 +20 Akebono Clearance-rays-te37sl.jpg
Old Jun 6, 2011 | 09:42 AM
datsunHEAD's Avatar
datsunHEAD
it should fit
Old Jun 6, 2011 | 03:56 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
Originally Posted by datsunHEAD
it should fit
Hmm, just need verification then I can pretty much go ahead and order...
Cheston feel like cutting cardboard or should I do it and send it to you?
Old Jun 9, 2011 | 02:29 PM
Chebosto's Avatar
Chebosto
send me the template and ill cut and fit.
if the template is anything near the 6 piston Stoptech ST60, it'll clear fine...i have a ton of room with the ST60 and the spokes... and a plenty of clearance on the barrel side.
i know this isnt the best picture but check out the shadow of the spokes on my caliper... it arches wayy out
another
Old Jun 9, 2011 | 03:50 PM
Wired 24/7's Avatar
Wired 24/7
Dr. Wired
I used this template with success - it showed me that my front SF challenge wouldn't fit without a 5mm spacer.
http://www.conceptzperformance.com/i...nttemplate.pdf
I just taped it to cardboard and exacto'd it out, leaving ~2mm of excess cardboard.
You are awesome for doing this. I believe it will fit just have to be sure.
another
Old Jun 10, 2011 | 01:44 PM
TreeFiftay350's Avatar
TreeFiftay350
haha I like how you included the dog, sexy rims though
Old Jun 11, 2011 | 10:39 PM
Chebosto's Avatar
Chebosto
according to the CZP template, the 14" front Akebono brake will extend nearly 22mm closer to the spokes than my ST-60s, and extend 11mm taller toward the barrel than the St-60s.
using those measurements, it (the 14" akebono brakes) will clear the Weds Sports SA55m in 18x10 + 18 RR face both in spoke and barrel. (measured against the wheel using ruler)
y Akebono so wide and tall????
416blueZ
Jun 11, 2024 10:56 AM
