10.5 too wide?
Old Sep 10, 2011 | 10:45 AM
rey rey_10's Avatar
rey rey_10
Default 10.5 too wide?
I was looking at some wheels for purchase, the only thing worrying me is the width.. 10.5 20+ offset.. is this doable?
thank you for your input.
Old Sep 10, 2011 | 10:57 AM
KingBaby's Avatar
KingBaby
Hardest Setting
yes
5amascii's Avatar
5amascii
I have xxr 518's on mine with a 3inch lip dunno the offset, but in the front i have a 10.5 rim with 275/45R18 tires and they barely barely dont rub, i have about have a centimeter between tire and the knuckle i guess is what its called, the backs fit no problem i run a 305/30R18, try searching the threads, someone has probably made a post with every possible tire size and rim you can run what works and what doesn't, i saw it once when i got my rims
Old Sep 10, 2011 | 11:01 AM
Ruthless18x's Avatar
Ruthless18x
No they are not.
Old Sep 10, 2011 | 11:08 AM
I don't think it has ever been done before. Be a pioneer. A 350Z trailblazer.
DavesZ#3's Avatar
DavesZ#3
Doable? Browse the Wheels/Tires forum and you'll quickly discover that 9½/10½ wheels setups are the most common upgrade around.
Old Sep 10, 2011 | 11:19 AM
SE5spd's Avatar
SE5spd
I have 18x8 +32 wheels and its almost too much, so no I dont think so.
Old Sep 10, 2011 | 11:23 AM
Flo-ridaZ33's Avatar
Flo-ridaZ33
19x9.5/10.5 +12 TE's... No problem
18x9.5/10.5 +15 RPF1's... No problem
19x9.5/10.5 +15 VSXX's... No problem
My car is slammed but not "HellaFlush" approved and I have a mild fender roll in the rear.
Old Sep 10, 2011 | 11:49 AM
teamevolution2's Avatar
teamevolution2
10.5 is what i use on my car with no fender roll they fit very nice. good luck with your choice.
Old Sep 10, 2011 | 12:15 PM
rey rey_10's Avatar
rey rey_10
I'm sorry, I forgot to mention that this is 10.5 all around.
Old Sep 10, 2011 | 12:51 PM
Looch's Avatar
Looch
https://my350z.com/forum/wheels-and-...ll-around.html
Old Sep 10, 2011 | 12:52 PM
ZS14RR's Avatar
ZS14RR
Standard.
Old Sep 10, 2011 | 12:55 PM
Duckeee's Avatar
Duckeee
didnt state offset but more than likely yes. more than likely..
Old Sep 10, 2011 | 01:13 PM
rey rey_10's Avatar
rey rey_10
thank you!!
Old Sep 10, 2011 | 01:55 PM
Spike100's Avatar
Spike100
10.5” wheels with a 22mm offset is perfect, and it fits the front and rear on a 350Z
If you are that wide on the front, you will probably mount 275mm tires. With that setup you will notice slightly heavier steering and probably some bump-steer as well. That’s no big deal.
--Spike
Old Sep 10, 2011 | 02:05 PM
03threefiftyz's Avatar
03threefiftyz
18x10.5 +15 with 285/30 Hoosiers (run wider than street tires).....no problem.
I do have some camber in front -2.8. Ride height is 25.3 from ground to center of fender. On custom shocks and high spring rates, though.
Car was dirty and the headlights have since been cleaned...
Old Sep 10, 2011 | 02:45 PM
gotboost36's Avatar
gotboost36
yes it will fit i have 18x10.5 0 offset on all 4
Old Sep 10, 2011 | 09:23 PM
miLes.'s Avatar
miLes.
My theory on wheel fitment... Get the size u want and if it doesn't fit... make if fit.
Old Sep 11, 2011 | 06:18 AM
gotboost36's Avatar
gotboost36
^true words...
Old Sep 11, 2011 | 10:05 PM
Waiz's Avatar
Waiz
In this thread:
https://my350z.com/forum/2003-2009-n...questions.html
This post would have shown that you can easily run this setup..
https://my350z.com/forum/2487452-post8.html
Justin100
Nov 25, 2021 06:26 AM
bcoffee20
Nov 19, 2015 06:39 PM
irishguy0224
Sep 22, 2015 06:57 PM
onefastdoc
Jan 10, 2003 12:44 PM
Driven
Dec 23, 2002 06:34 PM
