Recommended Tires for FI
Old Mar 6, 2012 | 06:07 PM
  #121
etownz33's Avatar
etownz33
Originally Posted by f150intally
so if you run bias in the rear what are you SUPPOSED to run in the front? It seems bias + bias would be SUPER squirrely but apparently not according to what I have seen on the Interwebs.
Bias..... due to the construction of both they handle differently from one another. The bias ply is not as quick to handle movement.. If the fronts are radials and lets say you make a tiny jerk to the left on the steering wheel. The fronts will move immediately. The bias ply in the rear will move but slower... this leads to massive over correction usually with catastrophic results. So by running Bias and Bias you dont have to worry as all 4 are in tune with each other and handle as one
Old Mar 7, 2012 | 03:41 AM
  #122
Alberto's Avatar
Alberto
Cranky FI Owner
I had a TERRIBLE time with a radial/bias combo years ago. I tried a 10.5" tire instead of my 11.5" slick and my car/alignment did NOT like it. The sway was downright ridiculous, but it sure was fun lol.
Enjoy the crap combo....I sold the 10.5" after this.
http://www.youtube.com/watch?v=qe8bB...2&feature=plcp
Old Mar 7, 2012 | 04:53 AM
  #123
djamps's Avatar
djamps
I run 11.5" bias ply with radial on the front and there is minimal sway... nothing like alberto had but enough where it feels like a slight constant drift on normal roads. I think I aborted twice in 30 runs.
Old Mar 7, 2012 | 07:16 AM
  #124
Alberto's Avatar
Alberto
Cranky FI Owner
When I ran high 11's I never aborted a run on the same setup. 100whp more vastly chaned things in my car.
Old Mar 7, 2012 | 12:18 PM
  #125
rcdash's Avatar
rcdash
Originally Posted by Robert_K
I did a lot of reading before going with the R888. Read want the Supra owners thought, Porsche Turbo/GT3/GT2, Viper ACR, and even a Spec Miata. And other than the wet (lack of) traction and noise the R888 gets a lot of praise. I was really tossed up but thought that since my Z, hopefully, won't be my daily anymore I'll be good with a more "track DOT" versus a "max high-performance" summer tire. Now to just stuff them in there.
I was pleasantly surprised with R888 wet traction. The noise was the only issue for me. Quick wear, but that's to be expected.
Old Mar 7, 2012 | 12:45 PM
  #126
f150intally's Avatar
f150intally
That junk was scary looking
Old Mar 7, 2012 | 01:38 PM
  #127
eltness350's Avatar
eltness350
The Untouchable
^^ nutty!
Old Mar 7, 2012 | 03:01 PM
  #128
P&K350Z's Avatar
P&K350Z
Robert, I run R888s and I have found that lateral traction is great. Straight line I would consider them medium. I realize that there are several opinions on this but they stick like all get out on corners at MSR but I do have to mind a straight launch, especially when the pavement is cold.
As you know mine is not a DD so I have not been caught in many wet afternoons, but when I have, it is not fun. Houston highways have turned to crap and the tires float on the runoff.
Anyway, I have a set of NT05s in the garage waiting until I finish burning these off. After I try those I'll decide whether to go back to R888s.
Old Mar 12, 2012 | 05:26 AM
  #129
Robert_K's Avatar
Robert_K
Didn't Go Cheap
Thanks for sharing. If I remember correctly the NT05's were not offered in the sizes I wanted/needed. I was really limited first by 19's. Than with a 265/30 & 305/30.
Old Mar 12, 2012 | 08:12 AM
  #130
scotts300's Avatar
scotts300
I get the same "sway" on my Z32TT. It comes in around 110mph, and it's like you're driving a boat. I still can't get the 1/2 shift without bogging in second gear. I see how long you stay in first to get traction, then slam it into 2nd. What kind of 60's were on these runs? I can get 1.6s, but don't ride out first gear long enough to put the car back into the power band in 2nd. I know I need to do that, though, to get my 10s pass.
Old May 10, 2012 | 03:21 AM
  #131
alexml's Avatar
alexml
Default Best tire configuration going FI
YES i make my reaserch
but didnt find any treat especific to my subject.
i need someting more especific for my problem.
i´m going FI with Vorthec and i´m aiming for 380/400rwhp and i have to buy new tires right now.
I´m looking for the best tire configurantion for my FI 350z.
if i have to put on some spacers thats ok...
what can i do to inprove the OEM configurtion?
Old May 10, 2012 | 03:23 AM
  #132
alexml's Avatar
alexml
i´m using the OEM configuration
OEM Volk Rays wheels with 225/45R18 and 245/45R18
Old May 10, 2012 | 06:30 AM
  #133
str8dum1's Avatar
str8dum1
on stock rims,
def go mickey thompson drag radial 2 265/40/18 (http://www.summitracing.com/parts/MTT-3782R/) in the rear and pretty much any 245/40/18 in the front.
that will keep your current front to rear aspect ratio and give you all the hook up you need.
Old May 10, 2012 | 07:29 AM
  #134
terrasmak's Avatar
Buy new wheels, simple and easy. If you have FI money, you should have no problem buying some cheap $1400 wheels. If you don't have that type of money, you shouldn't be going FI.
Old May 10, 2012 | 07:40 AM
  #135
alexml's Avatar
alexml
Originally Posted by str8dum1
on stock rims,
that was my inicial bet... but after reading some thinks i ended up with this chart
http://www.tyres-pneus-online.co.uk/...es-advice.html
so if i´m using rear 18x8,5 wheels i cant put on the 265/45R18
what u think? is it safe?
I´m going fast so i dont whant any desnecessary risk
Old May 10, 2012 | 07:45 AM
  #136
alexml's Avatar
alexml
seriously?
do you think that any cheap wheel is compared to Volks even if it is OEM?
ok, lets assume that i spend 4/5k on a set of Volks. what u think i should buy on tires?
Old May 10, 2012 | 08:17 AM
  #137
str8dum1's Avatar
str8dum1
i run 275s on the stock rims when I dyno my car which is over twice as much power as you are looking at. Believe me, 265 is just fine on a 8 or 8.5" rim.
i even have pics of it somewhere that I posted.
Old May 10, 2012 | 10:41 AM
  #138
Waiz's Avatar
Waiz
I would really suggest that you review this thread we already have for meaty tires:
https://my350z.com/forum/wheels-and-...es-thread.html
Several of the regular posters in that thread are already FI including the OP who started the thread
Old May 10, 2012 | 10:53 AM
  #139
blAk mAx's Avatar
blAk mAx
Going to try out the nexen n3000
Old May 10, 2012 | 10:58 AM
  #140
Boosted Performance's Avatar
Boosted Performance
Vendor - Former Vendor
I recently installed a set of 295/30/19 RE08's and I am very happy with them. They grip better than anything I have had in the rear up to now. No slip at all at about 450whp. I am going to go back to the 3.5 fd but with the Quaife LSD (have the OEM 3.3 in now).
