Wheel Recommendation???
Old Nov 2, 2011 | 10:59 PM
hachansoo0413's Avatar
hachansoo0413
Default Wheel Recommendation???
Hey guys
what is the biggest wheel for Z without fender roll ?
I wanna have the tire size of 275 or 285 on rear / 245 or 255 on front with 18 inch wheels.
Will this fit in Z ?
Old Nov 2, 2011 | 11:33 PM
terrasmak's Avatar
18x10.5 +30 will fit out back without rub with a 275/40-18. With a 5mm spacer installed i started to rub. Just roll the rear fenders, i did a nice roll and run a 10.5 +10 out back. An 11 or 11.5 inch wheel will easily fit with a roll and some nice 305 tires.
atrain858's Avatar
atrain858
Originally Posted by hachansoo0413
Hey guys
You can go up to 20" depending if you are lowered or not. I have 20"
Old Nov 3, 2011 | 12:05 AM
-Trav-'s Avatar
-Trav-
You could go 20 regardless
Old Nov 3, 2011 | 01:23 AM
4DGS's Avatar
4DGS
What ever diameter you want and as long as the camber is zero'd you can fit a 10.5 +22 with a 275/35 (19)
But technically you said wider.... you could run up to an 11.5 without need a roll but the offset would be somewhere around +34
Old Nov 3, 2011 | 07:26 AM
JERZ350's Avatar
JERZ350
Think they answered it nicely. Personally I think 19" looks perfect on Z's. Depending on the style I think a lot of 20" wheels looks a bit too large to the point where it starts to look a little silly. Again my opinion. Sometimes this pops in my head:
I went to Florida recently and saw these all over the place....the most silly and retarded looking things i've ever seen.
Old Nov 3, 2011 | 08:05 AM
DjTyfightr's Avatar
DjTyfightr
^ dam, thats one sweet ride. need to get me some of those rims
Old Nov 3, 2011 | 12:59 PM
rimmed up with killers system
Old Nov 3, 2011 | 06:24 PM
Itz_Gizzy's Avatar
Itz_Gizzy
i currently have 275s on the rear with a 9.5" wide, 18" diameter wheel. no problem, i'm at about +15. You can run a 11.5" wheel without a problem if you wanted to i believe. Not sure why you'd want to though....this isnt a corvette z06...
Old Nov 3, 2011 | 08:01 PM
Waiz's Avatar
Waiz
Start here:
https://my350z.com/forum/2487452-post8.html
Then Finish here:
https://my350z.com/forum/wheels-and-...ead-index.html
