Square Setup?
Nov 14, 2011 | 08:40 AM
Square Setup?
Will running the same size tire all around the car have a negative effect on daily driving or on the car itself?
Nov 14, 2011 | 08:45 AM
no its fine.... i run 225's all around and no problems...
Nov 14, 2011 | 09:14 AM
Depends on the trim level. VDC/TCS need certain differences to work correctly.
Nov 14, 2011 | 11:20 AM
^ yep depends on trim..although non-base models of certain years arent affected by a square setup, according to those who have ran it.
Nov 14, 2011 | 12:19 PM
You don't own a 350Z so don't worry about it.
Nov 14, 2011 | 01:16 PM
I have an 03 touring. No vdc. Second question is can I run 17" rims if they aren't stagered?
Nov 14, 2011 | 01:35 PM
ths thread went from ' guy who wants a square set up for autocross'
...and has quickly turned into
" i want to put wheels on my car that are starting to sound like they are not made for my car"
our fault for assuming the prior and not the later.
Nov 14, 2011 | 01:46 PM
Quote:
Originally Posted by
Seeyea
This is going to end badly...
Nov 14, 2011 | 02:14 PM
It's a matter if having started a new job, which ate up my savings in the process, and not having enough dough to blow on a brand new winter tire setup now that the snow has flown. So, might look dumb but I'd rather that then end up sliding er into something while on bald summer tires. That would look dumb
Nov 14, 2011 | 04:59 PM
This is probably the worst and most worthless thread I've ever read here.
--Spike
Nov 14, 2011 | 07:44 PM
Do a search for "square setup" it's been discussed many times
416blueZ
Jun 11, 2024 10:56 AM
350Z_Al
Oct 29, 2020 07:44 PM
416blueZ
Sep 24, 2015 02:11 PM
