PSA: When asking "will this rub"....
Old Mar 12, 2018 | 05:57 PM
  #441
travlee's Avatar
travlee
Master
Originally Posted by Ivanrobles253
The rims that are for sale are x8.5 and x10.5 and I wanted to make sure they’ll fit. Do you think it’s worth it to buy . Thank you for the feedback
no..... find better
Old Mar 12, 2018 | 06:24 PM
  #442
Ivanrobles253's Avatar
Ivanrobles253
It’s for a daily. Would it look funny or can it like mess up the car in the long run
Old Mar 12, 2018 | 10:30 PM
  #443
MicVelo's Avatar
350Z/370Z Tech Moderator
No, it won't "mess anything up" other than the possibility of it looking a little off (but not anything terribly noticeable). Whether it's "worth it or not", no way to tell, don't know what kind of wheels you're talking about. It's not just about the size it's about the type of manufacture it is. If they are forged Volks or some MAT Enkeis then maybe. Cheap gravity cast, well, they're going to be junk regardless of size unless all they're for is street/commuter use.
Old Mar 12, 2018 | 10:39 PM
  #444
Ivanrobles253
  1. they are Volk TE37. Bad thing is they are 5x120 lug so I’m Also stuck on if I should buy an adapter for it or keep looking. They’re selling fit 1800
Old Mar 13, 2018 | 01:44 AM
  #445
travlee's Avatar
travlee
Master
Get the right lug pattern
Old Mar 13, 2018 | 02:04 AM
  #446
MicVelo's Avatar
Keep looking. Hmmmph, perish the thought of putting BMW wheels on a Z!!
Old Mar 13, 2018 | 07:37 PM
  #447
zerafian's Avatar
zerafian
Originally Posted by travlee
someones exaggerating
Old Mar 14, 2018 | 06:01 PM
  #448
Ivanrobles253
Front 19x9 with tire size 245/35/19 offset 22. Rear 19x11 285/30/19 offset 23 volk TE37 with michelin sports tire with 65% tread left for $3500. is it worth it? and will the rims fit in my car with that tire size
Old Mar 14, 2018 | 08:50 PM
  #449
Ivanrobles253
Im planning on buying 18x10.5 ssr rims and I'm also planning on buying new toys tires but don't know which size to get without rubbing. I'm on stock height. And would these rims with tires rub?
Old Mar 14, 2018 | 09:42 PM
  #450
terrasmak's Avatar
Will fit, but TCS will not like it.
Old Mar 14, 2018 | 09:54 PM
  #451
Ivanrobles253
what about the SSR rims? any tire recommendations?
Old Oct 11, 2018 | 08:26 PM
  #452
bobbyhit's Avatar
bobbyhit
Default Tire and wheel fitment
Getting 245/40/18 or 255/40/18 with 18" x 8 1/2" +20 offset and 275/40/18 with 18" x 9 1/2 " +20 offset. 2006 Nissan 350Z roadster. stock suspension. Any problems seen? Thank you
Old Oct 11, 2018 | 08:30 PM
  #453
MicVelo's Avatar
Nope. Works fine.
Old Mar 24, 2019 | 05:58 AM
  #454
nonutz's Avatar
nonutz
Default 17x9.5 +38, 5x114.3, hyper black. 245/17 Hoosier H2O
See these at an amazing deal gonna use this as my drag set since the set are forged and enEki figured they'd be good for a weight reduction and wider than stock for drag night.
Old Mar 24, 2019 | 06:09 AM
  #455
travlee's Avatar
travlee
Master
Hella sunk in
Old Mar 24, 2019 | 06:10 AM
  #456
nonutz's Avatar
nonutz
Default ???
Guess that's a no?
Old Jun 17, 2019 | 05:54 PM
  #457
Panic's Avatar
Panic
Was asking noob tire size and spacer questions but found everything here:
https://my350z.com/forum/wheels-and-...ml#post7149697
Old Jul 22, 2019 | 02:05 PM
  #458
RA010325's Avatar
RA010325
Default Is it possible?
So i'm in the market for 350Z and would like to know in advance is my desired wheel/tire combination even close to fitting
265/30R19, 19x9.5 et12 or 22
295/30R19, 19x11 et22
I would like to keep the camber between -1 and -2. Car would be getting coilovers and lowered ~2-3cm (around 1"). Rolling and slightly pulling the fenders is fine.
Old Sep 21, 2019 | 11:42 AM
  #459
MufficanWhatSon's Avatar
MufficanWhatSon
I'm looking to put 50mm (2") spacers on all tires.
225/45/18 front and back
stock height and camber to my knowledge. 03 touring
Old Sep 21, 2019 | 06:19 PM
  #460
MicVelo's Avatar
So what’s your question?
