PSA: When asking "will this rub"....
Old Sep 21, 2019 | 06:33 PM
  #461
MufficanWhatSon's Avatar
MufficanWhatSon
Originally Posted by MicVelo
So what’s your question?
Will it rub?
Old Sep 21, 2019 | 07:21 PM
  #462
travlee's Avatar
travlee
Master
Why 50mm spacers? Balla on a budget?
Old Sep 21, 2019 | 09:14 PM
  #463
MicVelo's Avatar
350Z/370Z Tech Moderator
What wheels? Size, offset?
And why such narrow tires? Front stock size fine, but rears?
Old Sep 23, 2019 | 08:00 AM
  #464
MufficanWhatSon
It came with these tires and the 50mm will get me to flush with the body
  #465
MufficanWhatSon
The car came with them
Old Oct 1, 2019 | 04:15 PM
  #466
Rblong3's Avatar
Rblong3
Hello. I’m running stock suspension on a 06 I just bought. Will this setup rub?
Front 18x9 25mm
255/40ZR18 Michelin Pilot Super Sport
Rear 18x10.5 20mm
275/40ZR18 Michelin Pilot Super Sport
Thanks
Old Oct 1, 2019 | 05:08 PM
  #467
MicVelo's Avatar
OK, got it. Shouldn't rub with a tire that narrow. But you might want to run your combination through the wheel tire calculator: https://my350z.com/forum/tire_rim_calculator.php
I use 20mm spacers for my high offset Z34 front wheels but don't trust something as big as 50mm but so long as you follow proper torque sequencing and check them regularly, most likely be OK.
Front 18x9 25mm
Rear 18x10.5 20mm
Thanks
Fronts OK, rears MIGHT have interference (but I doubt it). Just take it easy once they're on and listen carefully for rubbing over bumps. I have +14, +22s and +23s (rears), but I couldn't tell you for sure if they'd rub as my guards are rolled (because my 9.5 +15s DID rub on select bumps.)
Old Oct 2, 2019 | 02:32 AM
  #468
Rblong3's Avatar
Rblong3
Thanks
Old Oct 2, 2019 | 05:43 AM
  #469
dromo3's Avatar
dromo3
Nismo 57cr clubsport spec wheels 18 x 10.5 +22
285/35-18 square set up
Will be running ast 5200 coilovers and whatever other suspension to get it to work. I am trying to stay in the STU class for autocross and max out the tire. I am assuming i will need to run higher camber and maybe a spacer in the back?
Old Oct 2, 2019 | 05:52 AM
  #470
travlee's Avatar
travlee
Master
you will rub front and more than likely rear, roll the rear fenders, camber in the front
not sure if acidjake still works on cars, but he is in carrollton as well
Old Oct 2, 2019 | 05:53 AM
  #471
dromo3's Avatar
dromo3
Is there a better offset for both that would work?
Old Oct 2, 2019 | 06:25 AM
  #472
travlee's Avatar
travlee
Master
it not going to be the offset, it will be the width and tire sizes. someone with more knowledge, aka micvelo, will chime in at some point
i was running 18x9.5 +15 rear, and +23 front, i had to roll rears and had to take the center fender liner screw out
255-/40 and 275/40 tire combo
Old Oct 2, 2019 | 06:31 AM
  #473
dromo3's Avatar
dromo3
hmm. maybe i need to go with the rpf1s 18*10's (+23 or +12?) with the 285's. I don't mind rolling the fenders, just can't stretch them.
Old Oct 2, 2019 | 06:47 AM
  #474
travlee's Avatar
travlee
Master
wait until mic or terrasmak chime in.... they both have more knowledge than me
Old Oct 2, 2019 | 07:30 AM
  #475
MicVelo's Avatar
Couldn't tell you about running a squared 285 setup for AX. Wait for terrasmak or others. I know he runs 275/35-18 on 10.5s squared but not sure on 285s up front.
Old Oct 2, 2019 | 09:11 AM
  #476
terrasmak's Avatar
Rear is fine , may rub the fender under full compression depending on your camber spec
front is ok, but you will need an adjustable arm for camber to clear the fender.
Tire size is nice, but look at the 275/35-18 specs for the tire prior to buying. The 275 in my brands was wider and lighter than the 285, doesn't make since but .....
Old Oct 2, 2019 | 01:07 PM
  #477
dromo3's Avatar
dromo3
Would +12 offset be better than the +22 or would that cause it to have less room?
Old Oct 2, 2019 | 08:04 PM
  #478
terrasmak's Avatar
That would not help you at all.
Old Oct 2, 2019 | 08:16 PM
  #479
MicVelo's Avatar
This. ^^^
+12 offset moves your rotating assembly 10mm closer to the guard lip. And with the widths you're talking about..... you need to go inboard more.
Old Oct 14, 2019 | 08:31 AM
  #480
GrapeJelly's Avatar
GrapeJelly
How will 19x10 245/35/19 +35 square set up fit on stock suspension?
