Question, square setup, 18x10.5 +30, 295/35
Hi everyone,
I was wondering if anyone can tell me how these wheel and tire combo will fit on a 2005 base with stock height and non brembo brakes.
Enkei NT03+M 18x10.5 +30, 295/35
I'm planning on lowering the car eventually but wanted to know if there will be issues with the front.
Thank you.
Thank you.
Hate to be that gu6 but the above post didn't help much.
Won't fit without spacers and I hope you have flares cause the spacer with that tire will rub. For instance I ran 285 with a 10.5 +22 and was mm off the spindle in the front. You want a bigger tire and higher offset and thsts a no no
I see, thank you guys for that information.
Ultimately, this is the initial setup I was thinking about:
18x9.5 +27 (5mm spacer) 265/35, Front
18x10.5 +30 (15mm spacer) 295/35, Rear
However, I found a good deal for 4 18x10.5 +30s and was curious how it would work.
I run those wheels with a 285/35-18 square setup. I also run a 10mm front space and 20mm rear spacer.
