350z wheel fitment issues
Old Oct 3, 2019 | 10:00 PM
z33killa's Avatar
z33killa
Default 350z wheel fitment issues
Hello, a couple days ago i got my varrstoen es1 19x9.5 up front and 19 x 10.5 in rear, love the wheels got them in candy gloss red. unfortunately i am running +12 offset not a big deal but wanted +22 that was out of stock. i am running 255/35 in the front and 275/40 in the rear. The ride height sits so high up and i cannot go any lower with out rubbing. i’m wondering what i can do to get lower like i want? All my fenders are all rolled. My friend recommended a camber kit but not a big fan of camber although some cars can pull it off. If i run smaller tires would i be able to drop it more? Wider fenders is out of the picture since i spent most of my money on reps lol. Thought i did all my research but i guess not. ***note the picture doesn’t really do justice on how high the car sits, photo actually makes it look low
Old Oct 3, 2019 | 10:38 PM
terrasmak's Avatar
You need a camber kit, set the camber to allow your drop
Old Oct 4, 2019 | 02:54 AM
travlee's Avatar
travlee
Master
if you continue to lower it, you will need a camber kit anyway.
Old Oct 4, 2019 | 03:33 AM
z33killa's Avatar
z33killa
have any recommendations?
Old Oct 4, 2019 | 03:36 AM
travlee's Avatar
travlee
Master
Spc, spl, kinetix.....what's your budget
Old Oct 4, 2019 | 04:41 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Rear tires are wrong. 275/35-19 needed.
35 aspect may not help because the offset is causing it to be pretty tight but we’re talking about a fair amount of height. (>1")
Old Oct 4, 2019 | 07:39 AM
z33killa's Avatar
z33killa
so would i just need the control arms to get some camber and drop it ?
Old Oct 4, 2019 | 07:51 AM
travlee's Avatar
travlee
Master
https://www.z1motorsports.com/suspen...ts-p-5311.html
Old Oct 4, 2019 | 09:17 AM
terrasmak's Avatar
Looking at the picture, I'm willing to bet he actually has the proper tire.
Different note, front upper control arm will allow for all the needed front camber adjustment. Rear will need Camber arms and toe bolts , unless your trying to be stupid and slam the car, then you need a camber arms and toe arms with a true style coilover
Old Oct 4, 2019 | 09:36 AM
MicVelo's Avatar
Yah, likely a typo because from the oblique angle, it does look right. But if it is a 40, that could certainly make a significant difference on fit.
Old May 6, 2020 | 06:45 AM
Panman's Avatar
Panman
Following this. In the same situation.
Feedmebearzilla
Mar 20, 2014 11:27 AM
JeffJohnries
Dec 27, 2011 06:07 PM
wicked7o7
Jun 5, 2011 01:55 PM
SdRider
Jun 6, 2007 06:04 PM
Ilov350ZEE
Jan 21, 2007 08:44 PM
