Found some wheels that will work
Old Aug 24, 2021 | 06:15 AM
KBoltz's Avatar
KBoltz
Default Found some wheels that will work
Found some wheels that will fit. 18x9.5 Konig +35 offset.
Will a 275 square setup fit ok at stock ride height with those dimensions?
Going to run that size for autocross.
Old Aug 24, 2021 | 10:22 AM
MicVelo's Avatar
350Z/370Z Tech Moderator
Which Konigs? Was watching the guys at the tire shop mount up some Hypergrams this morning. Nice wheels, very light, strong.
Offset is a little high but will likely sit about 10-12mm outwards from stock (higher width). 9.5, you can go down to about +20mm without any fender issues.
On tires, 275-what? 35 or 40? Yes, width is width but height on a 40 might give some issues up front. Remove the liner bolt if there's rubbing; that's where the most contact is going to be. If you run 275/35, you'll be fine.
Old Aug 24, 2021 | 03:30 PM
KBoltz's Avatar
KBoltz
Konig Freeform in bronze. 18 x 9.5 . Has 235 now, but 275/35/18
Old Aug 24, 2021 | 04:34 PM
KBoltz's Avatar
KBoltz
In Bronze on my Daytona Blue ZR
Old Aug 25, 2021 | 04:50 AM
Heel Til I Die's Avatar
Heel Til I Die
A hardtop roadster?
Sorry - couldn't resist.
Old Aug 25, 2021 | 05:27 AM
KBoltz's Avatar
KBoltz
Smart ***!
Only damn picture I could find.
Old Aug 25, 2021 | 07:15 AM
Heel Til I Die
Lol. I like that color with the DB. As Wheel King Mic said, the offset is kind of high, but if you plan on keeping the wheels for a while or want to swap them over to other vehicles, you'll have more versatility.
Old Aug 25, 2021 | 07:18 AM
KBoltz's Avatar
KBoltz
Talking
Keeping them forever according to my wife.
Old Aug 29, 2021 | 01:41 PM
KBoltz's Avatar
KBoltz
Looks good. Now to get the 275 Kenda
Old Aug 30, 2021 | 05:34 AM
KBoltz's Avatar
KBoltz
Default Mic
The OO of the wheels had them on his 370Z - he used spacers for the rear. He gave them to me. If you look at the pics I posted, it pushed the rears to where they are just about flush.
I am going to order the Kenda Kaiser KR20A tires. eBay has them really well priced at 500 a set of 4 with shipping included. I figured at 300 treadwear, I could use them for both Street and Autocross and be able to buy several sets for the cost of one set of Michelin Pilot Super Sports. Even if they aren't as good. Though the reading I've done has been almost ALL positive. Good treadlife with EXCELLENT grip, almost like a 200 Treadwear tire.
So, the fronts are where I need to be aware of rubbing issues. Will keep a lookout - but will go with your size recommendation of 275/35/18 to minimize any chances of rubbing
Old Aug 30, 2021 | 02:32 PM
MicVelo's Avatar
Just one caution.... do you have VDC? If so, a 275/35 square setup may upset that with no height delta F-R (wheel speed differential). Be sure to disable VDC if you autocross-only on them. If you run them on the street with VDC, this might be an issue. Disable at switch, but to do it right, fully disable: https://my350z.com/forum/engine-driv...bling-vdc.html (amongst other threads here.)
Old Aug 30, 2021 | 02:55 PM
terrasmak's Avatar
front won’t rub on the outside, and you can easily add a 10mm spacer. The rear shouldn’t rub will a 25mm spacer is added
Old Aug 30, 2021 | 03:20 PM
KBoltz's Avatar
KBoltz
Just one caution.... do you have VDC? If so, a 275/35 square setup my upset that with no height delta F-R (wheel speed differential). Be sure to disable VDC if you autocross-only on them. If you run them on the street with VDC, this might be an issue. Disable at switch, but to do it right, fully disable: https://my350z.com/forum/engine-driv...bling-vdc.html (amongst other threads here.)
No VDC, just TCS so a square setup is fine. I ran a square setup 245 40 17 on 17 x 8 stock wheels on the street as well as autocross
So, no VDC just TCS
Old Sep 12, 2021 | 01:49 PM
KBoltz's Avatar
KBoltz
Default Tires on buuuuut
The tires did NOT CLEAR the uprights. Had to use a 25mm spacer.
Ended up using 30mm in the rear to make it look even.
Old Sep 12, 2021 | 01:50 PM
KBoltz's Avatar
KBoltz
DS - you can see that I am replacing the door handle.
Old Sep 14, 2021 | 03:43 AM
KBoltz's Avatar
KBoltz
And the rear is rubbing slightly on the outside when I hit a bump. Going to switch out the 30mm spacers to 25mm spacers tonight.
Dammit, it's always something.
Old Sep 14, 2021 | 05:53 AM
eZg's Avatar
eZg
Damn the bronze looks killer on daytona
Old Sep 16, 2021 | 04:17 AM
KBoltz's Avatar
KBoltz
Swapped out the spacers, now no rubbing - it was only doing it on one bridge on my drive to work due to the undulations caused by the expansion joints on the bridge. Drove it the last two days and no ill effects.
And the door handle is replaced, no more ghetto style opening the car from the pax side.
Old Sep 16, 2021 | 04:19 AM
KBoltz's Avatar
KBoltz
Funny thing, Bro. When my wife and I went to pick up the wheels, she's like whatever.
After mounting the wheels, she's like, yeah you're right, it looks good. Especially after I got some real meats on the wheels instead of the 225's that were stretched to fit on the wheels. Made it look like rubber bands on the wheels.
chaseleonardnc
Feb 27, 2021 06:39 PM
bisdakr
Jan 20, 2008 03:39 PM
jwttz
Jan 15, 2008 01:50 PM
willyd6869
Dec 11, 2006 08:39 PM
DrAxe
Nov 14, 2002 07:17 PM
