Fix-A-Flat and other similar products... good?
Old Apr 2, 2004 | 12:44 PM
jreiter's Avatar
jreiter
Default Fix-A-Flat and other similar products... good?
I no longer have a spare, so I was thinking of carrying a couple bottles of Fix-A-Flat or some similar product in my car. I do have AAA, but it'd be nice not to have to wait on them out in the middle of nowhere if I don't have to.
So anyway, can anyone comment on how well those Fix-A-Flat type of products work? Any better than others? Also, any problems using it with the factory tire pressure sensors? I can't see any reason why the sensors might get messed up (other than coated with slime), but I wanted to check and see if anyone's had any experience.
Old Apr 2, 2004 | 01:29 PM
protocav's Avatar
protocav
i have heard, from more than one source, that the chemical that comprises fix-a-flat will eat through aluminum wheels. i wouldn't chance it!!
it is made for old-style steel wheels.
Old Apr 2, 2004 | 01:37 PM
teh215's Avatar
teh215
Not to mention the damage it could cause if it gets into the Tire Pressure Sensor...
Old Apr 2, 2004 | 01:45 PM
Rushguy's Avatar
Rushguy
I took my dealers advice and got AAA Plus. I would never use the spare unless I was trying to escape a tornado or something.
Old Apr 14, 2004 | 08:29 AM
tiswicked's Avatar
tiswicked
I tried using the Pennzoil Fiz a flat crap on my old supra about a year ago and it sucks. I just got the flat, pulled over, put one can in, did nothing, put a second can in. Still did nothing. I was very disappointed, I had to jack up the car and put in the spare. The tires were 245/45. Maybe they were too big??? IT didn't even inflate much if any.
Also tried another Pennzoil fix a flat on a friends sentra and it worked great. In one minute the tire was completly full from being flat. Worked great on the sentra. I think it had 175/70/13 tires.
Old Apr 14, 2004 | 09:05 AM
BriA5's Avatar
BriA5
BMW Distributes what they call an "M\\ Mobility Kit" when their cars don't have spares or run-flats. I think it is basically a can of sealant stuff and a mini, cigarete lighter-powered air compressor to pump yourself back up. Anyone have any experience with these? If you were getting rid of your spare this could be a great little kit to carry instead, if it works well.
Old Apr 14, 2004 | 04:33 PM
jreiter's Avatar
jreiter
Yeah, I wouldn't think that a can or two of tire sealant could fully inflate a flat tire. A small air compressor would be ideal. (But I imagine it would take a while to pump up.)
Old Apr 14, 2004 | 06:58 PM
BriA5's Avatar
BriA5
That's true, it could take a while to pump up. I know my father used to have donuts in his Porsches, but they would be deflated to save space. They provided a similar compressor, but the one time we needed to use it it took quite a while to do its thing. With the exception of the time factor, this method seems the simplest and cleanest to me.
Old Jul 22, 2004 | 12:10 AM
03 Z for ME's Avatar
03 Z for ME
The Corvette Z-06 has the same "kit"... A can of Sealant and a portable air compressor. No Spare - No Run Flat tires.
All I want to know is if the Fix a Flat crap will harm the Tire Pressure Sensors...
Old Jul 22, 2004 | 04:12 AM
DavesZ#3's Avatar
DavesZ#3
From page 5-4 of the owners manual:
Old Jul 22, 2004 | 08:28 AM
KShep's Avatar
KShep
For those without TPS, no spare due to BBK caliper clearance issues and no AAA plus (checking in to that), would a viable option be:...?
Can of sealant and mini-compressor...should be room for it in the spare tire well.
Old Jul 22, 2004 | 04:29 PM
n8vz's Avatar
n8vz
Make sure you check the lable that the content is none-flammable.
Old Jul 23, 2004 | 02:24 PM
jreiter's Avatar
jreiter
Does anyone know the brands of sealant used in the Vettes and BMWs that come with those kits? I've decided I don't mind risking the tire pressure sensors. If I ruin one, I ruin one. Oh well. That's better than being stuck with a flat in the middle of nowhere.
I just want to use some good stuff. I figure the factory stuff that Vettes and BMWs use can't be too bad.
Old Jul 23, 2004 | 02:26 PM
jreiter's Avatar
jreiter
Regarding AAA Plus, I unfortunately can't get it right now. Should be able to in another 8 months or so, but right now I'm stuck with the regular plan.
07ZEKE
Aug 23, 2021 09:15 PM
Tochigi_236
Sep 27, 2015 03:40 PM
