Help with Door Courtesy Lights
Old 12-29-2015, 07:23 PM
ryanmackk
ryanmackk's Avatar
Default Help with Door Courtesy Lights
I want to install courtesy lights under my car doors to light up when I open the door like the dome lights.
I got these led strips and I need to wire them up. Can someone guide as to which wires to connect?
Door wiring for the driver
Courtesy led lights for under the door
Old 12-30-2015, 04:00 AM
travlee
Master
travlee's Avatar
Received 9,060 Likes on 6,523 Posts
what do the instructions say?
Old 12-30-2015, 06:44 AM
iideadeyeii
iideadeyeii's Avatar
The doors already have a light on them that turns on when the door is opened, right? (I've rarely driven mine in two years and it doesn't even have a battery in it)
If so, wire it to that.
Old 12-30-2015, 07:00 AM
beezee
beezee's Avatar
If you want the lights in the door itself you have to run the wires through the grommets. That process is a pain and risky it is not worth it imo. I did it when i upgraded my speaker wires. Not fun. You can tap into the dome light wires if you still want to do it
Old 12-30-2015, 07:05 AM
Heel Til I Die
Heel Til I Die's Avatar
Received 1,069 Likes on 757 Posts
I'm guessing that the wires from the LED driver are:
Red: Batt +
Black: Ground
Yellow: Positive trigger
If you search something like "puddle lights", "footwell lights", "led door reflector" or "tap into dome light wiring" then you should be able to figure out where you can connect them.
I know the red reflectors on my doors don't light up when the door is open so you'll likely need to get power from somewhere else.
Old 12-30-2015, 07:22 AM
dcains
dcains's Avatar
How can anyone do work on wiring without a VOM, especially when you can actually buy a pretty good one for <$20?
Old 12-30-2015, 07:26 AM
travlee
Master
travlee's Avatar
but that makes too much sense, they would rather come on here and ask to be spoonfed
Old 12-30-2015, 08:10 AM
travlee
Master
travlee's Avatar
simple google search got me here....
http://forums.nicoclub.com/underbody...y-t564780.html
Old 12-30-2015, 11:20 AM
ryanmackk
ryanmackk's Avatar
uh what? I have one. Where did I say I was a professional technician?
Old 12-30-2015, 11:23 AM
ryanmackk
ryanmackk's Avatar
Yo travlee you are so depressing man. You pay a monthly subscription fee to come here and b**** people off. I wish I would restrict you from posting on my threads and not just block you from my sight.
Because clearly... everyone in the world knows they are called puddle lights? Yeah, genius?
Take your unnecessary subscription into your little corner and stay there man.
miss.bosslady (10-27-2022)
Old 12-30-2015, 11:33 AM
dcains
dcains's Avatar
If you have a VOM poke around an find a wire that's switched 12V+ when the door is open. Isn't that what you're looking for? You might also check the schematics in the FSM. This is pretty basic stuff, no?
Old 12-30-2015, 11:40 AM
travlee
Master
travlee's Avatar
Old 12-30-2015, 12:37 PM
Heel Til I Die
I think you should be able to get some power from the window switch IIRC.
Old 12-30-2015, 01:36 PM
dcains
dcains's Avatar
I recalled seeing this thread some years ago, and the pics are gone now, but apparently this installer didn't find a switched power source in his Z:
https://my350z.com/forum/body-interi...eflectors.html
And, some company made a kit:
https://my350z.com/forum/interior/56...-set-bnib.html
Old 12-30-2015, 05:00 PM
jhc
General & Tech Moderator
jhc's Avatar
Received 2,225 Likes on 1,594 Posts
T-Rav, was that Rick Astley from back in the day?
Old 12-31-2015, 06:39 AM
Heel Til I Die
Since the pics are gone in the link that dcains posted, here's a diy thread that should help with the wiring. Pics are still good. It's for light up door sills, but it seems like you're trying to accomplish the same thing with your lights: https://my350z.com/forum/exterior-an...oor-sills.html
tnk210
02-03-2016 12:24 PM
CM576Malta
12-29-2015 06:49 AM
UZ_
12-24-2015 08:59 PM
JohnUKVetteNut
350Z Roadster
12-17-2015 09:15 AM
vh5150
12-15-2015 12:56 PM
Quick Reply: Help with Door Courtesy Lights
