JIC coilover install question which way to install rear spring?
on
I just recently put in a jic coilover setup into my z but had a question to ask the people that have this setup in their car. For the rear springs the way I have it set up like in these pics below. But I have the oem cone rubber thing at the top instead of that little rubber ring. I did not get that rubber ring when I got my coilovers. Is this how all you other jic people have the rear springs in? My friend jsut installed HKS and they have the metal tophat looking thing at the top and use the oem rubber piece for the bottom of the spring so now I am confused.
![](http://jic-magic.com/images/products/App-33-466-19.JPG)
If you're asking about the bottom part where the spring sits... yes, it's like that, metal on metal. My friend has the same coilovers and his is like that too. At first he was confused because it looks like it might slip off so he talked to the owner of JIC Usa at a car show and he verified the installation.
One thing I would do is take the rubber boot off your stock struts and put it on your Jic struts. It looks really prone to damage and dust. You don't want it to start leaking after only a few hundred miles.
please excuse my terminology as i'm not familiar with the names of all the parts.
i believe yours is upside down. the springmount (cone rubber) at the top goes into the metal collar (top hat with the 2 collars) where you adjust the height. the your spring should sit in the oem rubber spring thing in the spring bucket (bottom). at least, that's how my tein basics are.
there's no way the adjustments go in the spring bucket. it doesn't make any sense. if it's metal on metal, there will be corrosion, there is nothing to hold it in place, and you have to remove parts other than wheels to adjust the height.
were there not instructions? you can get the assembly drawings off the tein website for reference.
on
Yea these pics were from jic. So I thoguht that the install is fine how I have it. But then others like the guys who posted right after say its wrong. Which kinda makse sense since putting them in like this you cant even adjust the spring anymore if you wanted to. No idea what to do....
But also instead of that tiny rubber ring i have the oem cone at the top of the spring. Is this totally wrong? Should I contact jic to get one of the small rings they used in their install?
on
FOr the jic ones the metal collar does not allow you to fit the rubber cone into it like the tien ones. My brother has tien and saw that the collars were different. This is why i was so confused lol. Jic site doesnt have install directions on the site either
![Frown](https://my350z.com/forum/images/smilies/frown.gif)
on
the install in your pics looks correct - I have it installed the same way. Adjusting the rear height is a PITA b/c you have to remove the spring, but that's the way it's designed. (the heigh adjustment portion has a hole in the middle where you secure it to the lower OE bucket portion.)
Infiltrator!
![](https://my350z.com/forum/images/ranks/premier.gif)
on
Back in late 2003 or early 2004 we did have a owner here that modifed his oem upper spring seat to work with the jic parts. Unfortunately, when I found the original post awhile back the pictures links no longer worked and even though I did save the pictures on my computer, I can't find my copies. How thick is the rubber part Jic provides?
Shame the Jic design runs the height adjustment system hidden in the lower control arm.
HR Autoparts
HR Autoparts
on
Infiltrator!
on
spot welding the top of the rear shock mount? you mean where the shock meets the chassis? why would the oem upper spring seat have to be modified? now you guys got me really confused...
Infiltrator!
on
well, i just spoke to paul over at JIC, and for the OP, what is pictured is the correct way to install the spring. don't use the stock rubber pieces. the rubber ring is to ensure that the spring doesn't pop out so it is necessary. a hole is drilled through the lower spring perch and is bolted down.
on
Hi n1ck I also having problem installing the rear springs... mind tell me if I install the 12K rear spring from JIC can I still use the OEM Cone shape Rubber seat? Can the purple JIC spring fit into that OEM Cone Rubber seat at the top??? What about the lower Rubber seat? Thank you very much I installed everything except the rear set of springs!
on
![](http://www.z33driver.com/images/USCC/Event/Day1/USCC_KWclubsport2.jpg)
-J
