Brake pads wearing out abnormally quick
Old 04-12-2009, 09:54 AM
04zee
04zee's Avatar
Exclamation Brake pads wearing out abnormally quick
so i changed all my brake pads about a month ago with duralast gold pads and i noticed that my driver side rear pads are almost done.(compared to the passenger side which still looks semi-new) Ive also noticed that when driving and i come to a stop that brake smells a bit burnt. so i figured that, that piston is pushing too much is there any way to fix this. ive searched but no luck. i have also bleed the brakes.
Old 04-12-2009, 11:16 AM
SlowCoupe
SlowCoupe's Avatar
check your slider pins. they might be seized.
Old 04-12-2009, 11:54 AM
04zee
04zee's Avatar
i failed to mention that when i changed my brakes that piston popped out completely and i compressed it back in. ill check the slider pins make sure there greased properly thanks SlowCoupe
Old 04-12-2009, 01:59 PM
Xendric
Xendric's Avatar
Are you spinning the rears a bit too much while having ESP on by any chance?
Burnt smell seems awkward and could be a malfunction, meaning the pad might be touching the rotor even if you don't use the brakes, but excessive engagement of the ESP could result in fast and uneven wear of the rear pads.
Old 04-12-2009, 03:28 PM
04zee
04zee's Avatar
negative im not spinning the rears at all im talking bout normal driving and stopping conditions and i checked the slider pins and greased em up and seem to be working well. ill give driving with the esp(vdc) off see if that helps
Old 04-16-2009, 05:01 PM
04zee
04zee's Avatar
it has gotten ridiculous the brake pad is completely worn out. the metal sensor this is already rubbing the rotor? wtf its just that one caliper/pad thats wearing out
Old 04-17-2009, 12:23 AM
Xendric
Xendric's Avatar
Not sure if it's even possible, but maybe the installation was bad and the pad was rubbing on the rotor even when you were not braking.
If you replace the pads, see if you can turn the wheel with your hand without too much effort, while you have it jacked up.
Old 04-19-2009, 09:47 PM
04zee
04zee's Avatar
Your right cause now that the metal thing is rubbing its rubbing when im moving without pushing the brake and today i had to stop a bit hard not too hard but that tire locked up and only that tire skidded. and i didnt brake THAT hard. so how would i go about fixing this? why is this brake getting more force/pressure/fluid?
Old 04-29-2009, 07:43 AM
04zee
04zee's Avatar
i took the caliper apart and realized that the little rubber gasket thingy was ripped, could this have caused my problem?
Old 05-08-2009, 08:43 AM
ngynnhu
ngynnhu's Avatar
are you talking about the rubber on the outside or inside of the the piston. If its the outside then it's just a dust cover. The inside rubber is called the square seal, it is what returns the piston when u let go of the brakes. If that's torn then the piston won't retract all the way.. if the outside rubber is torn the inside could be contaminated with dirt and causing the piston to be stuck also. All of this would cause your brakes to be still slightly applied and the pad would wear out faster.
Old 05-08-2009, 11:20 AM
Z04
Z04's Avatar
this thread is proof that if you do not know what you are doing, have someone else do it for you.
Old 05-10-2009, 03:16 PM
SilverJDMCoupe
SilverJDMCoupe's Avatar
The first time you changed the pads, did you clean the area around the brake caliper piston before you pushed the piston back in to install the new pad? When that piston came all the way out the second time you did the rotors, possibly, well, most likely some debris got in there and caused the piston to drag. That torn seal is also a sign that debris cause the issue. If your not comfortable, you may want to take it to a shop to have them fix this up.....
Old 11-23-2020, 03:46 PM
Roger35z
Roger35z's Avatar
I’m having the exact same problem in my z, ive replaced the caliper 3 times now because my pads keep wearing out to metal2metal contact in like a month. I’ve replaced the caliper tried remounting and even done a brake flush idk what to do
Old 11-23-2020, 10:05 PM
terrasmak's Avatar
Received 2,284 Likes on 1,646 Posts
replace the slider pins
Old 11-23-2020, 10:21 PM
Roger35z
Roger35z's Avatar
I’ve gotten new ones with all 3 calipers and I re greased them
Old 12-01-2020, 03:24 PM
thekinn
thekinn's Avatar
You have purchased and replaced one entire caliper, three times? and still have the same problem? No offense, I'd revert to post #11 above.
Post some pics. maybe something obvious will jump out at us.
Old 12-02-2020, 03:28 PM
rustyschopshop
rustyschopshop's Avatar
Have you checked your hub bearing?
11-01-2015 05:25 PM
samansharif
09-25-2015 12:31 PM
Quick Reply: Brake pads wearing out abnormally quick
