Oil Pressure Gauge at 120+
Old 07-13-2015, 01:04 AM
noobie_1337
noobie_1337's Avatar
Default Oil Pressure Gauge at 120+
Hello,
Just noticed that my Oil Pressure Gauge suddenly jumped up to 120+ psi today (or maybe a few days but just noticed it today). When I turn the car to "ACC ON" it's sits at 75psi, but as soon as I turn on the engine it jumps up immediately to 120+psi. I suspect the OPSU but just wanted to check your opinions.
In case it is the OPSU, is this the correct part# 25070-CD00A?
http://www.courtesyparts.com/switch-oi-p-605884.html
http://www.thenismoshop.com/NISSAN-F...A-_p_1027.html
- 2005 Touring / 162k mileage
Old 07-13-2015, 05:06 AM
dcains
dcains's Avatar
Usually the sensor fails the other way - showing low or no pressure. A pegged gauge is usually grounded somewhere along its wiring. Did you have the dash apart for any reason?
Old 07-13-2015, 11:41 AM
noobie_1337
nah, never took the dash apart whatsoever... quick question though... isn't the oil PSU gauge supposed to remain at 0 when engine is turned off (or key on ACC position)?
Old 07-13-2015, 11:52 AM
dcains
dcains's Avatar
I don't know if the gauges have power or not with the key in the acc position. Look at the temp gauge with the engine warm, and that will tell you. But, if one side of the gauge is powered, and the other side has ground, the gauge will read full scale. That's about all I can offer - don't have the service manual, but that's probably your next step.
Manny00 (07-17-2015)
Old 07-13-2015, 12:28 PM
dcains
dcains's Avatar
What happens if you pull the wire off the sender? If the gauge goes to zero, it's the sender - if it still reads 120, it's something else.
Old 07-13-2015, 08:29 PM
bealljk
bealljk's Avatar
Received 1,282 Likes on 1,007 Posts
My gauge went out back in the day and it pegged at 120. The sending unit is notorious for going out. I think I paid $60 for a new one from CourtesyParts. Remove your old one and install your new one during an oil change.
Remember, the sending unit takes 11 ft*lbs of torque ... many people, myself included, have ruined the upper oil pan by over-torque'ing and shattering that fitting.
Old 07-31-2015, 06:27 PM
trop7blue
trop7blue's Avatar
I am experiencing this as well but mine has been stuck at 120+ for a few weeks when the engine is on. It goes to 0 when the engine is off. Is it a bad sensor?
Old 04-04-2021, 02:45 PM
superfishyall
superfishyall's Avatar
Was it the oil pressure sensor? Our car is doing the exact same thing. (I know this is an old thread.)
Old 03-17-2024, 05:11 PM
IOwnAZ
IOwnAZ's Avatar
Any updates, i have this problem and I'm about to embark on a long journey to try and fix it
trashcan
01-25-2023 05:29 AM
Fluxil
06-01-2014 06:01 AM
NissanGuy
05-01-2006 08:11 PM
RobertH
04-30-2006 07:47 PM
failsafe306
03-30-2006 11:01 AM
Quick Reply: Oil Pressure Gauge at 120+
