Power goal
on
Power goal
Just a little background currently have a nonsleeved bottom end build 881 compression. Was wondering with a greddy 18g kit on 91 725id and 255 walboro. Will I make good power on 91. I decided to buy a dw 300 320 pump and dw1000 injectors. On e85 15lbs where should the power be at?
Cincy brings up a good point but assuming that everything works like it should I could see you getting 550whp. Your 'bottle neck' will be your heads...a port & polish, higher flowing valves and cams will give you another 100whp to 150whp...
start a build thread ... interested to see how it turns out
on the Z, if all you want is 500 or so, I'd probably say it isn't because that can be done relatively easy on regular pump gas.
that said, I'd question a dw 300 even being enough on pump. I haven't looked into this in yrs, but I think a modded 255 will outlfow these 300 pumps.
IMHO, it can be. on the evo it absolutely is..
Modified as in opening up the outlet port?
OP where are you trying to get to? That may be a better approach to you being happy in the end...
jonnyidfw
03-17-2016 01:29 PM
