Buzzing sound when accelerating
Old 08-06-2015, 09:35 AM
turn350
turn350's Avatar
Default Buzzing sound when accelerating
I have a 3inch catback exhaust, aftermarket y pipe, stock cats, i have this noise that almost sounds like a burrower bee buzzing noise every time i accelerate/ am going a constant speed. I have looked everywhere on here and posted videos on facebook groups and no one can figure it out, i work at a nissan dealership and the mechanics cant even figure it out. I replaced both gaskets were the cats join the y pipe and it is still making the noise, Do any of you have a similar issue? Like i said it sounds like a buzzing noise almost like a powered razor (id post a video but it wont let me)
Old 08-06-2015, 09:51 AM
travlee
Master
travlee's Avatar
Received 9,048 Likes on 6,514 Posts
is it a resonated cat back? have you checked the head shields to see if they are vibrating
Old 08-06-2015, 09:56 AM
turn350
turn350's Avatar
It is resonated, and i took all the heat sheilds off when i installed the y pipe so there arent any heat sheilds on the car so thats why im getting frustrated
Old 08-06-2015, 09:58 AM
travlee
Master
travlee's Avatar
it is possible that the material in the resonator could be busted loose
Old 08-06-2015, 10:11 AM
turn350
turn350's Avatar
Should i just have a muffler/exhaust shop check it out then?
Old 08-06-2015, 10:12 AM
travlee
Master
travlee's Avatar
take resonated part down.... hit it with palm of hand, if it is loose you will hear it
Old 08-07-2015, 06:09 PM
dboyzalter
6 inch cawk is my fave!
dboyzalter's Avatar
Could stick your stock system back on and see if the noise goes away if you still have it. It's odd if a mechanic looked it over and couldn't figure it out unless they did a half assed 5 minute looks good to me bro kinda diagnostic. How are the heat shields on your exhaust manifolds and catalytic converters?
Old 08-29-2015, 06:32 PM
DaveJackson
Master
DaveJackson's Avatar
Bump. I'm having the same issue except it's mainly when I'm DEcelerating and it's pretty unique to about 1800-2500 rpm.
I do have resonated test pipes - Megan. I didn't think there was anything in the resonators. I thought they were just an empty cavity. Are you sure about ^this?
I crawled under it for a long time today and took the heat shield off of the y-pipe. No change. Listening very carefully under it, the noise is almost certainly coming from the flex pipe on the driver's side. It sound like there's a freaking marble rattling in there! But, you can't hear anything from tapping/banging on it without the car running.
If this resonator "material" is true, I bet a chunk came off and worked is way downstream to get stuck in the flex pipe.
Sound reasonable? Any other suggestions?
Old 08-30-2015, 05:37 AM
dboyzalter
dboyzalter's Avatar
If they didn't have any resonator material in them I think they would leave the word resonated out of the name. I know when i had a test pipe on my old car it wasnt called resonated because it was a straight piece of 3 inch exexhaust pipe.
But it sounds like you might have pinpointed your problem so you should probably remove that side of you y pipe and see if a piece of megan racing quality comes out of it.
Obadabot
06-18-2023 11:31 PM
wanderingstuden
01-28-2016 07:03 PM
Justin100
11-29-2015 03:58 PM
samansharif
09-25-2015 12:31 PM
Quick Reply: Buzzing sound when accelerating
