UPREV Cooling Fan Control Update
Old Apr 12, 2012 | 07:17 AM
Vince@R/TTuning's Avatar
Vince@R/TTuning
Vendor - Former Vendor
Default UPREV Cooling Fan Control Update
UPREV has recently cracked the cooling fan on/off temp code. On the VQ35 ECU's on the on on/off switch point is adjustable and on the VQ37's the on/off points with fan motor duty cycle is adjustable. The very first 350z ECU's (CD000-CD003) have not been cracked yet, the GTR and some Random ROM's as well.
If we have tuned you before and your ROM has this option, we will be offering to make this adjustment on your ROM at no charge
Old Apr 12, 2012 | 07:49 AM
hazehkg's Avatar
hazehkg
With all due respect, may I ask what is the benefit of this?
Old Apr 12, 2012 | 07:59 AM
Vince@R/TTuning
^^^^ factory cooling fans dont come on till 100°C (212°F). Now this is able to be lowered to say 85°C, helps initial heat soak which ultimately keeps the car running cooler
Old Apr 12, 2012 | 09:14 AM
denchan350gt's Avatar
denchan350gt
I have this option on my ROM tuned by you. Thanks Vince
This is good to help cool off the engine while you are waiting in line to drag race or auto cross.
Do the fans shut off during WOT or once your below that temp?
I just looked and mine was set at 205 C and can't change the values.
Also I'm getting the new longtubes installed monday for a N/A and Nitrous touch-up.
Derek
Old Apr 12, 2012 | 03:06 PM
thisishk350's Avatar
thisishk350
nice.
Old Apr 12, 2012 | 04:28 PM
djamps's Avatar
djamps
I have AC406 and only a single temp setting is there... no speed or duty cycle settings. Confirmed with Jared the 04.5's have limited fan control ability compared to newer ROMs. But it does work, I turned it down to 80c and the fans went full speed (louder then hell) at running temp. No idea if they have any vehicle speed cutoff...I wonder what kind of parasitic drag they cause not only in aero but on the alternator.
There also seems to be a new(ish) throttle table which seems much more intuitive than the old ones and also a fuel target delay setting.
Old Apr 13, 2012 | 08:08 AM
str8dum1's Avatar
str8dum1
another things to check when i get retuned.
Old Apr 15, 2012 | 06:48 AM
cdoxp800's Avatar
cdoxp800
Here a Screen shot for you all from my 2011 370
Old Apr 15, 2012 | 07:02 AM
djamps's Avatar
djamps
Nice... do you HR guys have full cam control yet?
Old Apr 24, 2012 | 04:32 PM
UMW350Z's Avatar
UMW350Z
Very nice offer by RT, I had this installed, but I might have to adjust the point...the fans are on a lot of the time
hulkout
Tuning
Sep 30, 2015 12:33 PM
KOF
Tuning
Sep 30, 2015 04:09 AM
