16"s on a 350Z
Old Nov 27, 2004 | 07:56 PM
DIE DIE's Avatar
DIE DIE
Default 16"s on a 350Z
I know some people will think this is stupid, but does anyone know if you can fit 16"s on a 350Z base? I know that the brembo's require bigger rims, but how about the stock base brakes?
I probably won't do this, but I was just curious. I'm probably gonna get some 17" volk gram lights or something similar, only because they probably don't make the 16"s wide enough.
Either way I just want some light rims, and was wondering if anyone has done this or knows if it would work.
Thanks in advance and hi I'm new
Old Nov 27, 2004 | 08:01 PM
jeffie7's Avatar
jeffie7
some of the 19" volk wheels from what I've read are up to 5lbs lighter then the stock 17s
I'm pretty sure you could put 16s on the 350Z but keep in mind the 350Z has much bigger wheel wells then most other cars so if you do go with a 16" wheel you would see a lot more tire and if you went with low profile tires it would just look like a pansey car.
Old Nov 27, 2004 | 09:16 PM
DIE DIE's Avatar
DIE DIE
haha yeah I am more just curious to see if anyone has done it. But if I did it I would definately get some huge tires to try and fill the wheelwell.
Yeah... but if 19" volks are that light imagine 16" volks. Only problem is they probably don't make them wide enough. (if they'd even fit over our brakes. But like I said I'll probably go with 17" volks when I do get rims. I don't think the small gap I have now with the 17"s is bad. And it will be nice to pay less for tires since I hear they only last about 15K.
hey thanks for the input BTW!
Old Nov 27, 2004 | 09:19 PM
DIE DIE's Avatar
DIE DIE
FYI I also kinda wanted to see if there were a bunch of flamers like other forums, cause I know some people might just look @ the title of this and laugh Guess it didn't exactly catch many peoples eye
Old Nov 27, 2004 | 10:11 PM
uro279's Avatar
uro279
It's the weekend. Give til Monday.
Also, more tire=much more weight.
Old Nov 28, 2004 | 08:09 AM
cehome's Avatar
cehome
I can't imagine 16s on a Z. Those wheel wells are too huge for 16s. It would looke way off IMO
Old Nov 28, 2004 | 08:58 AM
2003z's Avatar
2003z
I had 16s on the rear of my Z with brembos. had to use 1" spacers for them to clear the brakes. Tires were M/T 26x9.50-16 ET Streets.
Old Nov 28, 2004 | 09:25 AM
DIE DIE's Avatar
DIE DIE
nice! I figured there would hae to be someone that has at least attempted it.
Thanks!
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
nanotech
Oct 2, 2015 05:02 AM
samansharif
Sep 25, 2015 12:31 PM
