Tire Noise
Old Jan 17, 2006 | 03:41 PM
sundevil67's Avatar
sundevil67
Default Tire Noise
I am wondering if anyone else has experienced this problem. I had replaced my original stock tires and wheels and soon after had noticed that I was ripping through tires WAY too fast. I had an accident where I totaled my Z, but on the damaged car I had realized that I again had worn out my tires. Several specialty alignment shops were at a loss and told me that Nissan had not released the proper specifications and that they could not repair the problem that was causing my tires to wear improperly. Finally I got a notice from Nissan that said there was a problem and that they would be reimbursing people for aftermarket tires and replacing stock tires. Well, I filled out all of the necessary paperwork and included all of my documentation. The other day I got a letter back saying that because I had gotten the repairs done at another shop (my dealer was not equipped to adjust my tires at all because they were too big at with 19" rims) that they were not going to reimburse me. I have driven less than 30 thousand miles and am on my 3rd set of replacement tires. This is insane! Anyone been successful in squeezing any money out of Nissan? I am getting ready to take them to court on this, because it just isn't right.
Old Jan 17, 2006 | 03:47 PM
VO...'s Avatar
VO...
Administrator
You will have no luck getting aftermarket replacement. Nissan will only replace factory OEM tires. Sorry to hear about your misfortune. Those are the rules.
Old Jan 17, 2006 | 05:19 PM
Yes. I replaced the front OEM tires with tires the same size and Nissan reimbursed the cost.
Old Jan 17, 2006 | 05:57 PM
steela2110's Avatar
steela2110
Old Jan 18, 2006 | 07:39 AM
arejohn's Avatar
arejohn
The TSB number is TSB04-043. Nissan will only address the tire noise issue if you have approved wheels. Proper alignment is a must. The update spec on toe-in is set it to max.
Old Jan 18, 2006 | 08:49 AM
UBERMENSCH's Avatar
UBERMENSCH
just take it back to the dealer and demand an explanation.! That is what I would do.
Old Jan 18, 2006 | 09:55 AM
sundevil67's Avatar
sundevil67
The dealer referred me to Nissan corporate. This is totally unfair - I replaced my stock tires and then after that had to replace my aftermarket tires twice because of this issue. Once Nissan released the new specs, I was able to have it properly repaired. Just because I chose to get larger rims and tires shouldn't absolve Nissan of this responsibility. I am going to continue to fight this and am going to file complaints with the FTC and the department of consumer affairs. This isn't right, I've been a Nissan customer since I learned to drive, and I should receive some sort of restitution here.
Old Jan 18, 2006 | 09:59 AM
sundevil67's Avatar
sundevil67
Default Hexed Z
It's really just another example of my horrible luck with this car:
Veilside Hood Debacle
Wreck #1
Wreck #2
And now I have a cracked windsheild.
Obadabot
Jun 18, 2023 11:31 PM
ablaine
Nov 29, 2016 10:13 AM
