oil gauge jumping to 120psi....
Old Feb 22, 2006 | 07:46 PM
uncutZ00's Avatar
uncutZ00
Default oil gauge jumping to 120psi....
i just got my oil changed with mobile 1 synthetic, and the oil gauge jumps to about 120 psi....
is this normal? the nissan dealership changed the oil. is thsi dangerous? or is the gauge sensor messed up?
Old Feb 22, 2006 | 07:53 PM
ericjackson's Avatar
ericjackson
its normal
Old Feb 23, 2006 | 07:14 PM
omfg3fiddyZ's Avatar
omfg3fiddyZ
Default Oil PSI
I just picked up my 350z today, and i noticed after driving around the oil psi gauge jumps past 120. is that normal or do i need to get something done?
Old Feb 24, 2006 | 05:11 AM
streetd's Avatar
streetd
mine only goes that high when it isnt warmed up yet, well it doesnt even go that high and I use royal purple.
Old Feb 24, 2006 | 05:59 AM
ericjackson
i think everyone w/ mobil 1 synthetic has it jump up to 120
Old Feb 24, 2006 | 06:32 AM
fahrenheit350's Avatar
fahrenheit350
It's normal esp. if it's a cold morning or when you start it after awhile. I just switched to Redline 10W30 and I am experiencing the same issue. Usually on a cold start it idles right around 60psi and under acceleration it's about 110-115psi, just make sure to take it easy for the first several miles or 10 mins until the oil is warmed up.
After the oil is warm, you will see normal operating psi; idles at 30psi and under acceleration at 60-90psi.
Old Feb 24, 2006 | 06:14 PM
omfg3fiddyZ
Default oIL psi
I havent seen it drop under 90psi yet, and it hovers around 120 +most of the time. IM just gonna go ahead and try an oil change. Besides DIY, any reccomendations on where to take it? How are places like Grease Monkey? i heard some horror sories.
Old Mar 20, 2006 | 01:23 PM
Yellow Stealth's Avatar
Yellow Stealth
Hmm... that's strange because I have the opposite problem. I run Mobil1 5W30 and under acceleration, my gauge always reads about 60psi, and when I idle, it drops down to about 10 psi. I thought the oil level might be low (2000 miles since last change) so I added 3/4 of a quart and it made no difference.
This is with outside temperature of about 55 degrees.
Old Mar 20, 2006 | 01:26 PM
StillAlive2029's Avatar
StillAlive2029
a little off topic but what is the oil that nissan uses since they do mine under waranty work and such, just wondering if they use synthetic or what
Old Mar 20, 2006 | 01:31 PM
Nexx's Avatar
Nexx
i believe they use good'ole dino oil. I've heard its usually castrol 5-w30.
Old Mar 20, 2006 | 02:03 PM
Mike Wazowski's Avatar
Mike Wazowski
OMG another thread about high oil pressure. If you would use the search function you would find that this has been addressed about 150 times in the last few months.
Here is a video that will help you with your posting on this forum since you are new here: http://www.starterupsteve.com/swf/posting.html
Old Mar 20, 2006 | 02:14 PM
slackjaw's Avatar
slackjaw
LMFAO, That should be a sticky
Old Mar 20, 2006 | 02:35 PM
Yellow Stealth
OK, laughs aside, I did a search and am not finding anyone with my problem (gauge never reads over 60psi under acceleration, and always around 10psi at idle) so I may actually have to start my own thread.
lapham3
Oct 7, 2022 03:15 PM
apex locator
Jul 23, 2021 02:27 AM
