the (!) light keeps coming on when hard acc and brake!!!
Old May 11, 2006 | 11:31 AM
dizaro's Avatar
dizaro
Default the (!) light keeps coming on when hard acc and brake!!!
Hey there,
I just got my Z this Jan and this just start happening:
When accelerate hard from stop, the parking brake light (the red light with the (!) ) came on and sometimes flashing, same thing happens with hard braking. It'll go away once the car slows down or stop from braking.
Anyone knows why?? car runs perfectly fine.
Old May 11, 2006 | 11:40 AM
abyss's Avatar
abyss
your parking brake fully released?
Old May 11, 2006 | 11:44 AM
Resolute's Avatar
Resolute
Check your fluid level, this sometimes happens when under hard braking or accel, the fluid shift causes the sensor to read a low level. Fill it up to the max line if it's not already and see if that fixes it.
Will
Old May 11, 2006 | 12:01 PM
Mathys's Avatar
Mathys
^+1
Check your brake fluid.
Old May 11, 2006 | 12:20 PM
dizaro's Avatar
dizaro
My parking brake is fully released. I'll go chk my brake fluid when i get home.
Old May 11, 2006 | 12:24 PM
tyandrews's Avatar
tyandrews
Newbie
mine does the same ill check my brake fluid when im home, but also the vdc and the slip light comes on and stays on for extended periods of time, sometimes on hard driveing, and others, it just turns on as soon as i start the car, would that be fluid too??
Old May 11, 2006 | 01:08 PM
roast's Avatar
roast
Yup, it's the brake fluid. Common occurrence.
Old May 11, 2006 | 01:16 PM
LIdrew's Avatar
LIdrew
Either the brake fluid or you need new Pads. Happened to me and my pads were done. How many miles since pads were changed??
Old May 11, 2006 | 01:32 PM
roast's Avatar
roast
Yeah, that's right, it could be the pads too. Although if he just got the car this year that is unlikely (assuming it's new). But yeah, as your brake pads wear your fluid will drop, causing the same thing.
Old May 11, 2006 | 01:38 PM
Havok_RLS2's Avatar
Havok_RLS2
(!) = Butthole light.
Old May 11, 2006 | 02:19 PM
abyss's Avatar
abyss
/\ lol
Old May 11, 2006 | 03:35 PM
Kolia's Avatar
Kolia
Brake fluid doesn't simply vanish.
If it's low, it's because the pads are worn. So don't just top it up! :P
Old May 11, 2006 | 04:22 PM
aren21's Avatar
aren21
The car I had before the Z did the same thing at one point(about 180,000 miles) its because of low brake fluid. I filled it, and everything went back to normal. While your at it, check your pads for wear also.
Old May 11, 2006 | 04:39 PM
roast's Avatar
roast
Not true!!!!
I don't know of many things that simply vanish without explanation. Just because the brake fluid is low doesn't mean the pads are worn. I've had to top mine off before and I had *plenty* of pad left. Then again, prior to that I cooked my brakes so some fluid probably boiled off, who knows. Maybe the brake fluid fairies came and stole it.
Old May 12, 2006 | 02:30 AM
Kolia's Avatar
Kolia
Originally Posted by roast
Not true!!!!
Darn brake fluid faries !
Just make sure you also check the pads wear. Not just top the fluid and go.
Dark Knight
Wheels Tires
Nov 11, 2015 08:40 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
Sleeper_Z
Sep 30, 2015 10:25 AM
samansharif
Sep 25, 2015 12:31 PM
