Car pulls when slowing down?
Old Sep 1, 2006 | 06:31 AM
nothingremains's Avatar
nothingremains
Thumbs down Car pulls when slowing down?
Has 2600 miles on it. Air pressure is correct. When slowing down once you get to about 20 mph it starts pulling hard to the left. Any possible causes?
Old Sep 1, 2006 | 06:35 AM
SS728's Avatar
SS728
Got any mods on it?
nothingremains
only an antenna
Old Sep 1, 2006 | 07:13 AM
semtex's Avatar
semtex
Could be an alignment issue. Have you hit any curbs or potholes in those 2600 miles?
Old Sep 1, 2006 | 07:16 AM
teh215's Avatar
teh215
My guess would be that that the left front brake is either grabbing too hard or the right front brake is losing grip. Could be air in the lines. Either way, I would take it somewhere to get looked at. Brakes are not something to mess around with. My 2¢.
Old Sep 1, 2006 | 07:17 AM
nothingremains
Since it is so new should i take it to nissan? what are the chances the alignment wasnt right when i purchased it?
Old Sep 1, 2006 | 07:30 AM
stein's Avatar
stein
^^+1
Also, is there any grooves in the road you're on? This will cause the car to pull left/right when stopping. Just thought I would throw that out there just in case. Other than that I'd have the dealer check it out.
Old Sep 1, 2006 | 07:34 AM
Ztalker's Avatar
Ztalker
one of your front tires might have a radial pull, its more common than you think.
Old Sep 1, 2006 | 07:35 AM
DavesZ#3's Avatar
DavesZ#3
Does it do it on all roads or just some, especially old blacktop roads? The reason I ask is that I have several heavily used old blacktopped roads around my neighborhood. I've always observed that the Z pulls either left or right when slowing down on those roads. It's easy to see the grooves worn into these roads so they tend to pull the car at low speeds.
Old Sep 1, 2006 | 07:39 AM
Ray123's Avatar
Ray123
these are all good thoughts. it should all be under warranty. i would say to go and have them fix this for you ASAP. if by chance it is air in the line i would rather you go and find out rather than learn it was this the hard way.
please let me know in a pm what it turns out to be ok. good luck man
Old Sep 1, 2006 | 08:49 AM
nothingremains
what is a radial pull?
etkms
Jun 19, 2022 06:30 PM
May 12, 2016 07:42 PM
RyansZ33
Sep 15, 2015 05:54 AM
roadmax
Sep 12, 2015 05:55 PM
