Starting car in reverse.
Old Sep 9, 2006 | 09:18 AM
nissannation's Avatar
nissannation
Default Starting car in reverse.
New member here btw, just bought a 2004 Performance Z about 3 weeks ago, lovin the car.
Anywhoo, this morning I was trying to paralell park on a hill...so I was trying to reverse into the spot, I am not 100% used to the clutch on this car yet so I stalled it on the hill trying to back up into the spot, anyways I started the car in reverse and I hear a BAD grinding noise comin from tranny, is it bad to start the car in reverse or something? I had the clutch completely depressed down, anyone have an idea why I heard a bad grinding noise?
Old Sep 9, 2006 | 10:02 AM
Escobar's Avatar
Escobar
It shouldn't matter as long as you had the clutch pressed all the way down. If it does it more I would take it to the dealer.
Old Sep 9, 2006 | 02:18 PM
06Firebase's Avatar
06Firebase
Cool
Escobar is correct. It doesn't matter which gear you are in if the clutch is fully depressed when starting your car.
However, if the car is moving at all when you try to shift into reverse it will grind. This is because of the synchronizers. Next time, make sure you are completely stopped before shifting into reverse gear.
Good luck,
Joe
Old Sep 9, 2006 | 02:23 PM
I never tried it.
Old Sep 9, 2006 | 02:24 PM
SIRCRASHALOT's Avatar
SIRCRASHALOT
i think you didnt depress the shifter right and were not in gear ........ push down and all the way right and pull it to you and done no more grinding
Old Sep 9, 2006 | 03:28 PM
roast's Avatar
roast
Are you 100% sure the engine was dead? Attempting to start a running engine will make a terrible grinding noise. It shouldnt matter which gear you were in. If you started the car in reverse with the clutch depressed, the lack of a reverse synchro is irrelevant. The transmission is already in gear and the engine is disconnected from the transmission.
Diagnosing problems just from a someones description is not always an easy/accurate thing to do, especially over the internet. If whatever the problem is persists, see a qualified nissan mechanic.
Old Sep 9, 2006 | 07:13 PM
kcobean's Avatar
kcobean
Mechanically, the car couldn't grind if you had the clutch fully depressed. The starter engages the flywheel only when you turn the key, so as long as the engine isn't already running and the clutch is fully depressed, no grinding would occur.
Old Sep 10, 2006 | 08:06 PM
efx's Avatar
efx
2 things might have happend...
1. you didnt push the stick hard enough and accidently put it on 6th
2. Since you were on a hill, all the fluids went on one side of the tranny
lolwatbro
Oct 9, 2021 04:58 AM
OdesiTT
Sep 30, 2015 10:47 AM
Katie93
Sep 15, 2015 05:57 PM
RyansZ33
Sep 15, 2015 05:54 AM
Darkspy
Sep 7, 2015 09:09 PM
