exhaust voiding warranty?
on
i dont know much about what an exhaust can do to your motor if anything happened and i was jsut wondering what can happen from the exhaust to mess up the motor thatll void your warranty if you install an after market exhaust? and what are the chances of it happening?
im asking because my uncle is a service rep at nissan and he told me not to do any mods until the warranty is up -_-
Guest
Posts: n/a
Originally Posted by zand02max
Tell your uncle he is an IDIOT! No offense but Nissan has to prove your mod did the damage. An exhaust will not damage your engine!
on
on
Originally Posted by davidv
How will the exhaust mess up the motor?
yah thats what i thought, he was trying to tell me about things going back into the motor or into the cats or something....and since i dont know a lot about exhausts....i was lost on the idea of anything going backwards when everything is flowing out....
on
These guys are right...nissan has to prove the mod caused the damage, HOWEVER, there is a good chance you would have to lay out the $ for the repair and then sue and is that really worth it? Correct me if I'm wrong but won't a Nismo exhaust leave the warranty in tact according to Nissan policy?
The manufacturer/dealer CANNOT "void your warranty".
The CAN deny a specific claim if they can prove that your modification directly caused the failure.
"Under the Magnuson-Moss Act, a dealer must prove, not just vocalize, that aftermarket equipment caused the need for repairs before it can deny warranty coverage."
http://www.dummies.com/WileyCDA/Dumm...e/id-2669.html
bill
bill
on
bill
bill
on
Possibly. If you are anxious then stay stock. End of story.
Everyone is correct that they have to prove that your modification caused the car trouble, but they can make your life hell by giving you the run around if something does happen...
Also if for some weird reason your engine fails just put your stock exhaust back on before taking to Nissan for warranty work
Performance Nissan
Performance Nissan
on
An Aftermarket Exhaust system will not void your warranty...
If there is a problem with the exhaust system its self, it will not be covered by your local NISSAN Dealer at NISSAN's expence... If the part interfiers with other warranty repairs the dealer can opt out of doing the repair or charge an extra fee for aftermarket parts or extra labor time that will be involved working with the exhaust system...
Example: Fuel Hose Recall Campaign... If an aftermarket exhaust is presant, an aftermarket gasket may need to be replaced and extra labor time may be involed to get the exhaust system lined up / re-installed properly...
If the exhaust system is a direct cause of a problem that part may not be covered under warranty...
Example: GReddy EVO 2 with the Fuel EVAP Canister relocation... If it is relocated improperly it may damage the EVAP canister... The part will no longer be covered under warranty...
on
thanks for the examples....it helps me understand it better
Performance Nissan
Performance Nissan
on
No problem!
Not sure if all of you know yet, but I am no longer in the parts department here... I am now in the Service department so I am dealing with alot of this stuff every day on all the different NISSAN cars....
on
j/k
Or as others have said, simply remove your exhaust before you go in for any engine work.
Good Luck!
R
Justin100
11-29-2015 03:58 PM
Tonyz_2004_350z
South East Marketplace
10-04-2015 12:53 PM
