350Z undercoating?
Old Feb 16, 2007 | 06:48 AM
Zya123's Avatar
Zya123
Default 350Z undercoating?
Do the Z's come stock with undercoating or some kind of primer to protect the metal? Where I live they put alot of salt down and I sometimes taking it out on those days and I sometimes hear the salt rocks hiting the wheel wells, Ive never heard that before with my other cars.
Old Feb 16, 2007 | 06:54 AM
joegengsta's Avatar
joegengsta
paint protects from salt.. but once that's gone.. there's rust.. you should probably learn some basic chemistry first
Old Feb 16, 2007 | 07:40 AM
ncparamedic's Avatar
ncparamedic
Prodigal Son
i think he might have meant the under carriage..
Old Feb 16, 2007 | 07:47 AM
jtabraham's Avatar
jtabraham
on modern cars, undercarriage coatings are not necessary. Underbodys are typically coated from the factory and use higher-corrosion resistant metals that will resists rust/rotting/corrosion for the life of your vehicle.
Now if you have a car made before the 90's then rust inhibitor coatings might be a good idea.
Hope that helps.
Edit: For peace of mind, whenever you wash your car, just spray down the underside also. Nothing else is needed.
Old Feb 16, 2007 | 08:11 AM
ncparamedic
Prodigal Son
Hope that helps.
+1 Good advice..
Old Feb 16, 2007 | 08:20 AM
03touringauto's Avatar
03touringauto
Default undercoating/sound deadening
I removed the plastic wheel liners and sprayed undercoating/sound deadening material in all the inner fender areas. The front wheel area allows you to access the front fender clear back to the front door. It is very noticeable in the reduction of noise. Also remove your rear mat and line the spare tire area with Carpet pad. You will be amazed how much better your cars sounds.
Old Feb 16, 2007 | 08:28 AM
realcom2's Avatar
realcom2
The dealer asked me if I wanted to add the sprayed under coating/sound deading stuff but IMO if I wanted the care to ride quiter I would have bought the G35.
Old Feb 16, 2007 | 10:23 AM
Yes. Look under the car.
liqalu04
Jan 2, 2022 12:58 PM
Dsowe
Feb 17, 2021 10:38 AM
issyz
Jul 2, 2017 03:04 PM
Mattg350z
Oct 2, 2015 06:51 AM
samansharif
Sep 25, 2015 12:31 PM
